flatpack on mobian
(01-19-2022, 08:30 PM)pajux Wrote:
(01-19-2022, 10:20 AM)beta-user Wrote: Does anyone know how to uninstall flatpak on Mobian Bookworm? It seems to be installed by default, but I don't want to install software through anything else than apt, because I don't trust it. When I try to remove flatpak it also wants to remove packages like mobian-phosh.
It's more important then to remove any flatpak installed + any repository. Once you do that, and if you never download and manually install a flatpak, you won't accidentally install any.
I haven't installed anything through flatpak. I don't think I've used it at all and it seems that it's included by default in Mobian and required by phosh. I don't understand why. Is phosh installed and updated through flatpak? I would have to check on a fresh install to be sure.
flatpack on mobian - by jyoung - 01-16-2022, 10:10 AM
RE: flatpack on mobian - by linmob - 01-16-2022, 10:31 AM
RE: flatpack on mobian - by jyoung - 01-16-2022, 10:36 AM
RE: flatpack on mobian - by beta-user - 01-19-2022, 10:20 AM
RE: flatpack on mobian - by pajux - 01-19-2022, 08:30 PM
RE: flatpack on mobian - by beta-user - 01-20-2022, 05:38 AM
RE: flatpack on mobian - by pajux - 01-25-2022, 09:39 PM
RE: flatpack on mobian - by beta-user - 01-26-2022, 03:17 AM
RE: flatpack on mobian - by user641 - 01-26-2022, 04:54 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,571 4 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,000 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 161 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,090 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,892 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 658 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,071 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,938 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 655 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,092 06-19-2023, 03:02 PM
Last Post: vusra
