PinePhone keyboard manual
When using the convergence dock with Pinephone in the keyboard case, the dock should be plugged into the phone USB-C, but where should the external USB-C power supply be plugged into?  The keyboard USB-C port or the convergence dock USB-C power input?
Is either scenario safe prior to power management software being developed?  Is the PM software being developed assuming one configuration or another?
With solely Pinephone branded accessories it is possible for the phone to have 4 power supplies at the same time.  2 battery, 2 external.
Just looking for any unambiguous way to safely have 1 external supply powering the phone and dock, even if it demands removing a battery or 2.
Re: keyboard key shims.  I just noticed that the ID of the shims here https://avery.cafe/blog/a-quick-fix-for-...s-top-row/ are very close in diameter to the 1/4" hole size of Avery 5729 hole punch rings.  The OD is a bit large but can probably be trimmed square with a blade once it is on the keycap.  I haven't tried this yet.  They are also available in plastic, or 13mm OD which might have 6mm ID.
If someone has a guilotine paper cutter they could trim several sheets of the rings to key sized squares fairly quickly. Shipping a partial sheet of trimmed ring shims inserted in the manual with new keyboard orders might help a bit to mitigate complaints from current keyboard stock.
PinePhone keyboard manual - by Luke - 01-11-2022, 06:03 PM
RE: PinePhone keyboard manual - by NoahAndrews - 01-11-2022, 07:51 PM
RE: PinePhone keyboard manual - by NoahAndrews - 01-11-2022, 11:16 PM
RE: PinePhone keyboard manual - by Tanabi - 01-27-2022, 01:31 PM
RE: PinePhone keyboard manual - by Tanabi - 01-27-2022, 06:04 PM
RE: PinePhone keyboard manual - by talpa - 01-28-2022, 10:47 AM
RE: PinePhone keyboard manual - by ragreenburg - 02-03-2022, 09:55 AM
RE: PinePhone keyboard manual - by slomobile - 02-02-2022, 12:23 PM
  Case for Pinephone totilele 13 7,570 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,982 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,366 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 674 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 455 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,276 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 479 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,291 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 546 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 646 10-21-2023, 02:55 AM
