PinebookPro Build Errors
Build Errors:
I am having a glitch, both of these packages are showing in the add/remove software "updates"
python2-cffi 1.15.0-1
python2-pycparser 2.21-1
I don't know where to start...
I have tried updating seperatly, but still get the same darn errors:
Preparing...
Cloning python2-cffi build files...
Generating python2-cffi information...
Checking python2-cffi dependencies...
Cloning python2-pycparser build files...
Generating python2-pycparser information...
Checking python2-pycparser dependencies...
Synchronizing package databases...
Warning: libtool: local (2.4.6+44+gb9b44533-11) is newer than core (2.4.6+42+gb88cebd5-15)
Warning: xorg-xwayland: local (21.1.2.901-1) is newer than extra (21.1.2-1)
Resolving dependencies...
Checking inter-conflicts...
Building python2-pycparser...
==> Making package: python2-pycparser 2.21-1 (Sun 09 Jan 2022 05:57:31 AM PST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
  -> Found python2-pycparser-2.21.tar.gz
==> Validating source files with sha512sums...
    python2-pycparser-2.21.tar.gz ... Passed
==> Removing existing $srcdir/ directory...
==> Extracting sources...
  -> Extracting python2-pycparser-2.21.tar.gz with bsdtar
==> Removing existing $pkgdir/ directory...
==> Starting build()...
running build
running build_py
creating build
creating build/lib
creating build/lib/pycparser
copying pycparser/c_ast.py -> build/lib/pycparser
copying pycparser/_ast_gen.py -> build/lib/pycparser
copying pycparser/__init__.py -> build/lib/pycparser
copying pycparser/ast_transforms.py -> build/lib/pycparser
copying pycparser/c_generator.py -> build/lib/pycparser
copying pycparser/_build_tables.py -> build/lib/pycparser
copying pycparser/c_lexer.py -> build/lib/pycparser
copying pycparser/plyparser.py -> build/lib/pycparser
copying pycparser/c_parser.py -> build/lib/pycparser
creating build/lib/pycparser/ply
copying pycparser/ply/lex.py -> build/lib/pycparser/ply
copying pycparser/ply/__init__.py -> build/lib/pycparser/ply
copying pycparser/ply/yacc.py -> build/lib/pycparser/ply
copying pycparser/ply/ctokens.py -> build/lib/pycparser/ply
copying pycparser/ply/ygen.py -> build/lib/pycparser/ply
copying pycparser/ply/cpp.py -> build/lib/pycparser/ply
copying pycparser/_c_ast.cfg -> build/lib/pycparser
==> Starting check()...
Generating LALR tables
WARNING: 79 shift/reduce conflicts
WARNING: 37 reduce/reduce conflicts
WARNING: reduce/reduce conflict in state 27 resolved using rule (type_specifier -> atomic_specifier)
WARNING: rejected rule (empty -> <empty>) in state 27
WARNING: reduce/reduce conflict in state 87 resolved using rule (type_specifier -> atomic_specifier)
WARNING: rejected rule (empty -> <empty>) in state 87
WARNING: reduce/reduce conflict in state 437 resolved using rule (statement -> pppragma_directive)
WARNING: rejected rule (empty -> <empty>) in state 437
.....F............................................................................................................................
FAIL: test_all_examples (tests.test_examples.TestExamplesSucceed)
Traceback (most recent call last):
  File "/var/tmp/pamac-build-peter/python2-pycparser/src/pycparser-release_v2.21/tests/test_examples.py", line 29, in test_all_examples
    rc, 0, 'example "{}" failed with stdout =\n{}'.format(filename, stdout))
AssertionError: example "using_gcc_E_libc.py" failed with stdout =
Ran 130 tests in 8.235s
FAILED (failures=1)
==> ERROR: A failure occurred in check().
    Aborting...
PinebookPro Build Errors - by mexsudo - 01-09-2022, 08:02 AM
RE: PinebookPro Build Errors - by fleamour - 01-14-2022, 01:14 PM
RE: PinebookPro Build Errors - by fleamour - 01-30-2022, 06:12 AM
RE: PinebookPro Build Errors - by mexsudo - 01-30-2022, 08:36 AM
  PinebookPro Display Corrupts/Cuts Out Twig 5 4,031 06-11-2023, 07:59 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 8,682 01-22-2023, 10:05 PM
Last Post: rfm83
  PinebookPro CPU Speed setting therosery 0 1,176 09-07-2022, 05:02 AM
Last Post: therosery
  Article: Build a Linux Driver for PineDio LoRa SX1262 USB Adapter lupyuen 3 4,625 05-26-2022, 11:09 PM
Last Post: lupyuen
  Standard Notes ARM Build (appimage, deb) mds08011 0 1,895 07-30-2021, 01:34 PM
Last Post: mds08011
  Virtualization on the PinebookPro astr0baby 25 37,591 04-27-2021, 09:02 AM
Last Post: moonwalkers
  Screen refresh delay with kernel errors shawnanastasio 31 49,493 04-27-2021, 02:57 AM
Last Post: james64
  PineBookPro does not charging floppy_rofling 0 3,735 02-03-2021, 05:29 AM
Last Post: floppy_rofling
Heart Zandronum 3.1 on PinebookPro PixelPaintbrush 0 2,310 12-08-2020, 09:59 AM
Last Post: PixelPaintbrush
  I/O errors from SD card slot? (Manjaro, kernel 5.7) zackw 5 10,867 10-28-2020, 01:16 AM
Last Post: 25519
