Pine64 $15 card killed my $120 keyboard
(06-30-2016, 02:06 AM)exa Wrote:
(06-29-2016, 06:50 AM)DonFL Wrote: Not that I'm disagreeing or disputing what you are saying, but....that seems a stretch.
I assume you've done a bit of troubleshooting with it plugged into your original computer..looked to see if it was recognized in device manager, verified you didn't have an issue with the usb cable, tried a different usb port, etc?
Just for grins I did a quick google and I see a lot of incidents mentioned related to K70 keyboards suddenly dying, nothing related to the Pine.
I did as I said on my first post
(06-29-2016, 08:54 AM)MarkHaysHarris777 Wrote: Yeah, the K70 has issues.
... no way plugging it into the PineA64 killed it, no technical way.
sorry.
It was working perfectly seconds before, the possible explanation is that my board being bare bones (as I didn't receive my case yet) my hand could have touched one of the pins while I plugged it.
sorry.
That is, not without doing something that would kill the pine64 at the same time... like shove 12v into it instead of 5v! That would toast both it and anything plugged into the USB ports for sure!!!  Big Grin
I'm using it with the power supply sent by the pine team
If you truely feel that the Pine destroyed your keyboard then just get someone qualified in electronics to test the port, the fact is that whilst a lot of people have got used to the idea that say a PC will fail safely, the pine is not a PC. It is instead a homebrew board that unlike the RPi is not aimed directly at school children interested in electronics, thus I would suggest may be missing a lot of protection that comes as standard with say a PC not least being a case.
Personally I would not have risked using an expensive keyboard and especially not one that has has failure problems or higher current drain to power lights/onboard electronics such as is normal for gaming keyboards.
So as no one here can actually say with certainty what is coming out of your USB port without testing it, especially the "pine apologist", I would have it tested by someone with the tools and competence to say if the keyboard was destroyed because it was plugged into a faulty USB port
The USB port may check out fine and it be, as your say, down to ECD which can damage pretty much any unhardered/un-isolated ICs, in which case you would need to show that pine suggested you run the board without basic ECD protection, not least of which is keeping your fingers away from the board whilst it is in operation.
Pine64 $15 card killed my $120 keyboard - by exa - 06-29-2016, 05:45 AM
RE: Pine64 $15 card killed my $120 keyboard - by Oscar - 06-30-2016, 04:00 AM
Question External storage problem for pine64 Dani6102 4 1,763 08-22-2023, 08:36 AM
Last Post: gulshan212
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,635 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine64 as wireless audio device S265 3 3,323 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,174 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,959 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,146 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,795 09-14-2020, 09:55 AM
Last Post: PaddyChan
Exclamation Can't boot when SD card inserted kivox 5 8,098 03-15-2020, 06:00 AM
Last Post: kivox
  Pine64 OS dpcons 2 4,989 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,855 02-17-2020, 11:39 PM
Last Post: vj-kumar
