Bluetooth Connection Issue
While InfiniTime 1.6.0 fixed a major issue with reconnection, it seems there's another cause of reconnection problems for some people that's yet to be found. Some have said it happens after enabling the heart rate monitor. I haven't been using HRM since its results are pretty bad at the moment.
https://github.com/InfiniTimeOrg/InfiniTime/issues/707
Secure pairing is currently in the develop branch if you want to compile and test it. They've been trying to avoid it being a breaking change for companion apps, sorting behaviour around how it interacts with the recovery process, and making sure it doesn't break OTA firmware updates. See for example:
https://github.com/InfiniTimeOrg/InfiniTime/issues/880
https://github.com/InfiniTimeOrg/InfiniTime/pull/796
https://github.com/InfiniTimeOrg/InfiniTime/pull/886
I haven't kept track of what the other firmware projects are doing. WaspOS uses a different bluetooth stack so is unlikely to share the same bluetooth problems.
Bluetooth Connection Issue - by Orionbelt - 12-29-2021, 09:28 AM
RE: Bluetooth Connection Issue - by wibble - 12-30-2021, 05:20 AM
RE: Bluetooth Connection Issue - by BrianPineFan - 11-24-2023, 05:27 PM
Sad Bluetooth Alternative? erikzoltan 4 1,552 08-23-2023, 06:39 AM
Last Post: erikzoltan
  Struggling to detect Pinetime over bluetooth John45595 0 1,201 11-20-2022, 11:06 PM
Last Post: John45595
  Pinetime Screen issue after bootloop troubles Spater 12 6,034 09-15-2022, 05:03 PM
Last Post: wibble
  Might there be a UV Radiation issue? jojuma 3 2,917 07-30-2022, 04:04 PM
Last Post: headgr
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 2,721 07-27-2022, 07:38 PM
Last Post: jahway603
Lightbulb Saving, loading, sending and receiving images via Bluetooth to and from Pinetime danimations 0 1,151 03-29-2022, 01:21 AM
Last Post: danimations
  Bluetooth pairing issues (Mobian, InfiniTime) johns 1 2,277 02-22-2022, 08:01 PM
Last Post: Arsen6331
  PineTime touchscreen wakeup issue norfolk_uk 1 2,139 11-15-2021, 08:01 AM
Last Post: Codenul
  Bluetooth: When discoverable? When pairable? DrPlamsa 0 1,394 08-16-2021, 12:34 PM
Last Post: DrPlamsa
  How to disable Bluetooth? piner67 0 1,507 07-08-2021, 05:42 AM
Last Post: piner67
