PineTime touchscreen wakeup issue
I've had my PineTime for a couple of weeks. I am running 1.4.0. Now my issue is with the touchscreen, specifically when trying to wake the PineTime with either a tap or a double tap. Sometimes I can tap it 10 or more times and it still will not wake up. Sometimes only pressing the button will work.
Once the PineTime is awake the touch screen is faultless, especially on 1.4.0 so I don't believe it is a hardware issue, although I am no expert. On 1.4.0 when awake, it is fast, fluid and sensitive.
From my experience of this issue, I do believe there is correlation with the unresponsive wake up taps and the length of time the screen has been asleep and/or correlation with the known issue of loss of Bluetooth connectivity with Gadgetbridge.
Upon successfully waking the PineTime, subsequent taps to sleep and wake again, repeatedly all work fine. The issue seems to become after the PineTime screen has been asleep for a while.
Can anyone else confirm this issue or does it appear to be just me?
Seeing that you within this post you are running the watch on 1.4.0 firmware. Just over the weekend, 1.7.0 was released. I would try to update to this newest firmware build and going from there / seeing if maybe this issue goes away.
One thing that was addressed in 1.7.0 is a quicker wake up timer. It does seem like it responses quick now when trying to wake up the device.
PineTime / InfiniTime Releases : Github
Cheers,
Proud Owner :
OG Pinephone
Pinetime
Pinetab
  PineTime at FOSDEM jmlich 5 871 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 268 01-31-2024, 11:57 AM
Last Post: tynstar
  Bluetooth Connection Issue Orionbelt 2 2,156 11-24-2023, 05:27 PM
Last Post: BrianPineFan
  PineTime and Amazfish on Ubuntu Touch jmlich 1 778 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 13,998 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,527 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,258 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 6,905 02-11-2023, 09:30 AM
Last Post: alexmitroff
  PineTime beginner MV1791 2 2,241 01-09-2023, 11:52 PM
Last Post: Canyonless
  Struggling to detect Pinetime over bluetooth John45595 0 1,181 11-20-2022, 11:06 PM
Last Post: John45595
