Real/Usable USB-C battery pods for Pinecil? (9-12v mode minimum)
(12-25-2021, 05:17 AM)VaZso Wrote:
(12-23-2021, 10:08 AM)biketool Wrote: What are the USB-C power standards we should be looking for?
USB-C seems to have several standards and it seems like it will take some time for the market to standardize or change the names of proprietary tech.
Pinecil supports USB-PD and it also supports QC.
QC is not really a standard protocol but PD is, so the better to look for a PD-capable power supply, but that also means a Type-C to Type-C USB connection.
Also, most power supplies may not support 20V over QC interface, but some of them do and also some of the PD-capable power supplies may not support 20V output.
So look for a 20V-capable power supply which has PD support or at least QC-capable.
So I ordered another shell ready for my lithium cells as my first one failed(explained above) failed; it says it is an S6 and does does up to 12v-1.5a and the following: QC2, QC3, QC4, QC4+, PPS PD3, PD2, AFC, FCP, SCP, SFCP, PE2, PE1
It should power a pinecil direct from the USB-C but only powers it from the two old USB ports and only at 5v so no soldering only can access the UI on the Pinecil.
It even tries to charge from my Pinephone when plugged in to the USB-C, so I am suspecting I got another counterfeit....
RE: Favorite USB-C batteries? - by biketool - 12-20-2021, 11:53 AM
RE: Favorite USB-C batteries? - by VaZso - 12-22-2021, 06:16 PM
RE: Favorite USB-C batteries? - by biketool - 12-23-2021, 10:08 AM
RE: Favorite USB-C batteries? - by VaZso - 12-25-2021, 05:17 AM
RE: Favorite USB-C batteries? - by biketool - 03-10-2022, 02:38 PM
RE: Favorite USB-C batteries? - by biketool - 04-23-2022, 01:26 PM
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 154 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 468 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 898 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 428 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,532 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 740 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,391 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,645 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,540 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,334 12-14-2022, 01:03 AM
Last Post: River
