DRM support in Android
Your Android device may come with DRM modules, but this depends solely on the device manufacturer or service provider. Some Android devices simply don't support DRM, but Netflix will still work. Because support can only be provided by some applications. You can check if your device supports DRM by clicking on the link and downloading the program
DRM Info https://play.google.com/store/apps/detai...ng.drminfo. Hope my answer was helpful. All the best to you!
DRM support in Android - by Wizzard - 11-21-2021, 08:37 AM
RE: DRM support in Android - by alanwake82 - 02-01-2022, 01:20 AM
RE: DRM support in Android - by Johnmo89 - 02-03-2022, 09:16 PM
  Android images for RockPro64 BitAnnihilator 1 93 04-17-2024, 07:50 AM
  Difficulty installing Android on Rockpro64 spammycheese 0 2,806 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,648 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 3,046 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,483 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 11,179 04-24-2022, 08:13 AM
Last Post: Rocklobster
  Install Playstore on Android 8.1.0 Domo 14 24,966 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 14,103 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 4,038 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 28,101 02-13-2021, 12:52 AM
Last Post: chisteven
