Red LED when trying to boot from SD card. Need advice.
I am now unable to boot from micro SD card. The only thing I have done that would be considered sensitive was flashing the open source firmware for the modem. That was the last major thing I did on my Pinephone running mobian. I only noticed it wasn't working last night b/c I flashed the SXMO image to a micro SD card. I was so excited because it seems like the best OS for me on the pinephone, just learned about it. It was a bummer to get the red led indicator.
I thought I did something wrong or my SD card was bad, so I bought a pack of 3 extra 64gb micro sd cards. All the same issue, when I press the power button with a SD installed the LED turns red and does nothing. I have done some research online but could not find a solution. I read that red LED means it detects the SD but there is a issue. I have tried 4 separate SD cards, I am using balena etcher to flash the images btw. I have used 2 different computers just to be safe. I did format and delete all the partitions from the sd card before flashing the new image. I did put in a empty sd card with nothing on it to see what would happen. Same red led.
To be clear it was working before, I have tested multiple OS's on the SD card previously. Manjaro Phosh, Mobian and I even used the SD card to make the pinephone's emmc flashable to install Mobian on the emmc. Only after flashing the open source modem firmware did I discover this issue. I only mention updating the firmware b/c that was the last major thing I did. I am not assuming it is the cause of the issue. I used GNU/Linux on and off for about almost 15 years. But I will be honest I still don't know much. So help a brother out. Thanks in advance.
TLDR: what steps can I take to troubleshoot my issue of not being able to boot from SD card?
Red LED when trying to boot from SD card. Need advice. - by サーバント - 10-18-2021, 04:37 PM
  PinePhone Beta dead - no boot-related output on serial interface horalocal 1 1,359 02-15-2023, 11:21 AM
Last Post: fxc
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,211 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,480 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 2,037 01-08-2022, 06:01 AM
Last Post: zooidic
  Pinephone wont boot after updating Phtevenz 1 1,589 10-26-2021, 11:31 PM
Last Post: bcnaz
  Won't boot until connected to power after sudden power loss brb78 1 1,745 08-30-2021, 12:41 AM
Last Post: bcnaz
  Fragile SIM card connector hakkou 1 1,839 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 6,603 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 4,009 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Mainboard replacement does not boot/charge boarf 2 2,793 05-02-2021, 10:47 AM
Last Post: boarf
