Won't boot until connected to power after sudden power loss
I've noticed that if the battery is pulled from a running system my Braveheart seems to become unable to boot any image - either SD or eMMC, until it is plugged into a power supply.
Is this a known issue? Has anyone else experienced it? And if you are experiencing a failure to boot after sudden power loss perhaps try booting with the power plugged in.
You should NEVER remove the battery while the Pine phone is running ! * (or from any phone for that matter)
There are many threads/posts here on the forum discussing this.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 477 02-17-2024, 04:15 PM
Last Post: vortex
  Pinephone - broken power button rorus 10 9,075 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,482 03-20-2023, 12:54 AM
Last Post: bcoyle
  PinePhone Beta dead - no boot-related output on serial interface horalocal 1 1,308 02-15-2023, 11:21 AM
Last Post: fxc
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 23,652 01-29-2023, 12:20 PM
Last Post: skandigraun
  Power supply vs battery albafrati 11 4,518 06-22-2022, 06:04 PM
Last Post: albafrati
  Pinephone won't boot from SD card arkadione 3 3,379 05-25-2022, 03:26 PM
Last Post: sfb
  Power consumption during the call some_pinephone_user 0 1,127 10-29-2021, 06:03 AM
Last Post: some_pinephone_user
  Pinephone wont boot after updating Phtevenz 1 1,555 10-26-2021, 11:31 PM
Last Post: bcnaz
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,176 10-20-2021, 09:40 AM
