Wifi and bluetooth disabled on pinephone arch-phosh
(10-15-2021, 04:58 AM)pineuser0 Wrote: The cellular, wifi, and bluetooth icons don't respond when tapped on the drop-down menu and the screen rotation  button seems to have reverted to switching between portrait and landscape rather than between locked and adapt. The gnome settings app also won't open even after a minute of waiting, whereas the terminal app opens within five seconds.
Now that I think about it, I somehow stopped using the cell/wifi/bluetooth icons since I found it more helpful + responsive to change that stuff from the settings app. Now if you really cannot open the settings app (after a restart?) I see two choices:
1a) find out which files the settings process is reading (top + lsof can be of help)
1b) delete some of those files (when you are reasonable sure it is a corrupt settings file)
2) start over, be it from a backup, sd image or jumpdrive
The settings app takes its time starting up, but it should not take more than 4 or 5 seconds (from the slowest eMMC in use).
From the same eMMC, starting the Terminal takes not more than 2 seconds.
So you -may- have a problem with the memory hardware (formatting / OS image corrupted during download) you are running your installation from.
RE: Wifi and bluetooth disabled on pinephone arch-phosh - by lacriz - 10-17-2021, 03:28 PM
  stuck between phosh and plasma aular 0 279 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 1,029 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,414 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 891 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 2,088 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,947 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 976 07-29-2023, 08:27 AM
Last Post: alpineduck
  wifi hotspot no route to Internet dieselnutjob 8 6,952 04-02-2023, 11:21 PM
Last Post: antisol
  No keyboard on Arch Plasma when entering password on document Chief 0 882 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,214 11-07-2022, 04:38 PM
Last Post: Ferriah
