SPDIF TOSLink Adapter Hat for Quartz64
The Quartz64 comes with an SPDIF output pin, so I've decided to make a little adapter board that converts this to TOSLink. With it, you can connect the Quartz64 up to your optical audio equipment. The board's design is open hardware, you can find the KiCAD files on GitHub: https://github.com/CounterPillow/quartz64-toslink-hat
[Image: toslink-hat-1-bigger.jpeg][Image: toslink-hat-2.jpeg]
The board plugs straight into the GPIO pins, and allows for stacking whatever else on top of it using the long pin legs. Only the front row of 3 pins is actually used, the back row is not connected and merely used for mechanical stability.
I've produced a small batch of these adapter boards, and am selling them for USD 9.99 (excl. shipping + customs) on Tindie. Check it out if you're interested, or make your own from the design files.
[Image: tindie-larges.png]
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
SPDIF TOSLink Adapter Hat for Quartz64 - by CounterPillow - 10-01-2021, 01:49 PM
  gpio on Quartz64-a jyoung 2 545 02-23-2024, 03:01 PM
Last Post: jyoung
  Quartz64 Model A fan TeutonicTovarish 1 1,077 05-20-2023, 04:45 AM
Last Post: diederik
  Is Quartz64 compatible with official 7'' Raspberry Pi display? maldus 1 1,094 02-05-2023, 09:28 AM
Last Post: CounterPillow
  SD card slot in Quartz64 model B psic4t 1 997 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 1,268 10-13-2022, 07:43 PM
Last Post: dml-pc
  Case for the Quartz64 Model B? kuleszdl 1 1,964 06-05-2022, 02:43 PM
