gpio on Quartz64-a
I'm trying to setup an LED indicator using the gpio pins on a Quartz64 model A. I've installed libgpiod, which comes with a number of  tools, like gpiodetect and gpioinfo. With these tools, I can detect a five gpio chips (0-4). However, I don't think that any of these are linked to the main gpio pins since each of the chips has 32 lanes, but there are only 20 gpio pins on the Model A. Also, very few of the 5x32 lanes are named, and the few names are things like "fan" or "restart", not the names listed in section 3.8 of the wiki
wiki.pine64.org/wiki/Quartz64
This is an excellent tutorial on gpio programming, which originally led me to libgpiod
plebian.org/running/gpio/
However, all the examples are for the Model B. I'd hoped that the setup and naming convention for the Model A would be similarly easy, but it seems not. Does anyone have insight for the Model A?
For context, I've tried this while running armbian and gentoo, and the results are the same.
(01-17-2024, 01:37 PM)jyoung Wrote: I'm trying to setup an LED indicator using the gpio pins on a Quartz64 model A. I've installed libgpiod, which comes with a number of  tools, like gpiodetect and gpioinfo. With these tools, I can detect a five gpio chips (0-4). However, I don't think that any of these are linked to the main gpio pins since each of the chips has 32 lanes, but there are only 20 gpio pins on the Model A. Also, very few of the 5x32 lanes are named, and the few names are things like "fan" or "restart", not the names listed in section 3.8 of the wiki
I've tried a few things, with limited success. This thread
forum.pine64.org/showthread.php?tid=14277
has a comment at the end that pin7 is an all-purpose gpio pin connected to gpio chip 0 line 0, so it can be turned on with
gpioset 0 0=1
That worked, but, how would one know that pin7 corresponds to 0 0? The output of gpioinfo doesn't seem to give any clues on this point.
gpioset 0 0=1
Actually, if anyone could just point out one additional line in the gpio that I could toggle, that would do it for this project. It kind of looks like pins 3,5,12,14 might be good candidates, but I can't tell what chips/lines they're connected to. Trying lines at random is kind of a mixed bag, since there are 5x32 lines, and some of the lines trigger a power off/restart.
  Quartz64 Model A fan TeutonicTovarish 1 1,045 05-20-2023, 04:45 AM
Last Post: diederik
  Is Quartz64 compatible with official 7'' Raspberry Pi display? maldus 1 1,069 02-05-2023, 09:28 AM
Last Post: CounterPillow
  SD card slot in Quartz64 model B psic4t 1 978 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 1,253 10-13-2022, 07:43 PM
Last Post: dml-pc
  Lowest possible power consumption on with everything disabled except GPIO inputs? Wookbert 1 1,445 08-19-2022, 03:13 AM
Last Post: Wookbert
  Case for the Quartz64 Model B? kuleszdl 1 1,938 06-05-2022, 02:43 PM
  SPDIF TOSLink Adapter Hat for Quartz64 CounterPillow 2 2,966 10-09-2021, 08:46 AM
Last Post: Bullet64
  GPIO Table Bullet64 1 2,505 06-29-2021, 06:40 AM
