Case for the Quartz64 Model B?
since the shop does not mention compatibility between cases for the Rock64 and Quartz 64 Model B -> are they compatible? If not, what case options are available for the Quartz64 model B?
Thank you!
The aluminium case for the ROCK64 is not compatible with the Quartz64 Model B because the power socket was moved. However, the Model B acrylic case is compatible.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  gpio on Quartz64-a jyoung 2 456 02-23-2024, 03:01 PM
Last Post: jyoung
  Is the USB 3.0 port still an issue for Q64 model A? andreas1107 3 1,466 12-11-2023, 09:27 AM
Last Post: diederik
  SOQuartz Model A baseboard Real-Time Clock stormwyrm 1 444 11-19-2023, 01:04 AM
Last Post: stormwyrm
  Quartz64 Model A fan TeutonicTovarish 1 1,035 05-20-2023, 04:45 AM
Last Post: diederik
  Survey for Model B Owners: Stereo Audio HAT CounterPillow 1 1,202 03-01-2023, 05:48 AM
Last Post: manning
  Is Quartz64 compatible with official 7'' Raspberry Pi display? maldus 1 1,052 02-05-2023, 09:28 AM
Last Post: CounterPillow
  SD card slot in Quartz64 model B psic4t 1 967 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 1,248 10-13-2022, 07:43 PM
Last Post: dml-pc
  3D Model / Technical Drawings pitchbent 2 1,638 10-05-2022, 02:01 PM
Last Post: pitchbent
  Open acrylic case olivercfc 0 1,059 07-09-2022, 04:53 PM
Last Post: olivercfc
