Can't update or install software
#21
There are many methods and software Apps available to "restore" your system.
But at this point I was assuming you just want to "install" a system that works..?
but maybe you are mixing installation methods and restore methods ?
For a basic installation,  everything your phone needs to operate should be on the 'downloaded' image..
( It does NOT have saved information it needs from previous installs)
For sake of simplicity,  I suggest trying Mobian or Manjaro 'Phosh',  ... download a recent release,
    ...  use Balena Etcher to flash the image to a 16 or 32gb sd card.
put that sd card into your phone and try 'booting' from that.
When you do boot into a new system, the first time it will take a little longer to boot - as it will "Resize" your image to use the whole sd card.
Next check that you have made all the correct entries in "Settings"  including the choices in  'Regions & Languages' and your wifi information.
  (Need to put at least one good/working phone number into your 'Contacts' - using format: country code > area code > Phone number - for testing calls)
and you will need accurate information to correctly fill-in your APN information, for cellular data use.
Then do your updates, they should work directly from the software store, *(this does require an internet connection)
***  Only -  If the semi-automatic store updates do not work, * then try to install the Gnome package updater, and do updates  from there.
"Re-start your phone"  ** ( I let the timer 'time-out' instead of clicking on the option to instantly restart)
You should now be able to call and sms text
I think it would be easiest for you to do the sd card installation first,
* AFTER  you have succeeded with the sd card,
  ***  it should be simpler for you to install to the phones eMMC later.
*** I suggest doing all the settings first, *  as a wrong or unmade choice can possibly  affect your ability to download updates.
There are a multitude of different methods that will work, * but the steps are not all inter-changeable.
 I chose Mobian and Manjaro OSes as I think your odds  for out of the box success, ... are best with those.
  ***(I would pick Arch over Manjaro personally, but sometimes Arch needs to be tweaked 'out of the box')
For Test purposes the 16 & 32gb micro-sd cards work very well, *But you can use from 8gb to 2Tb micro-sd cards.
When I first started playing with the Pine Products (Pinebook Pro) I used an old Dell laptop with Ubuntu on it,  as that was easiest
for me to install a working copy of Balena Etcher on.
Since then,  I have had a 99+% success rate using Balena Etcher to do hundreds of micro-sd card flashes.
  Using the sd cards is great,  you can swap sd cards in about a minute to compare different OSes, or just different releases.
** There are a Lot of very smart members here on the forum, but sometimes their explanations are a bit too technical for us GUI users.
   As a GUI user I have been extremely successful in making my Pine products work.
See the thread  'Bookworm'  for some of my recent Mobian OS test results, * which recent releases work or do not work "Out of the Box".
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Can't update or install software - by P3TER - 09-23-2021, 08:17 PM
RE: Can't update or install software - by bcnaz - 09-23-2021, 11:31 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 01:51 AM
RE: Can't update or install software - by bcnaz - 09-24-2021, 08:46 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 09:38 PM
RE: Can't update or install software - by bcnaz - 09-24-2021, 09:48 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 10:00 PM
RE: Can't update or install software - by kqlnut - 09-25-2021, 03:05 AM
RE: Can't update or install software - by kqlnut - 09-23-2021, 11:50 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 04:09 AM
RE: Can't update or install software - by kqlnut - 09-24-2021, 10:30 AM
RE: Can't update or install software - by bcnaz - 09-23-2021, 11:56 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 02:10 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 05:33 PM
RE: Can't update or install software - by kqlnut - 09-24-2021, 06:48 PM
RE: Can't update or install software - by bcnaz - 09-25-2021, 02:17 AM
RE: Can't update or install software - by P3TER - 09-25-2021, 04:03 AM
RE: Can't update or install software - by bcnaz - 09-25-2021, 12:40 PM
RE: Can't update or install software - by P3TER - 09-26-2021, 01:04 AM
RE: Can't update or install software - by bcnaz - 09-26-2021, 03:43 PM
RE: Can't update or install software - by P3TER - 09-26-2021, 05:14 PM
RE: Can't update or install software - by kqlnut - 09-27-2021, 02:19 AM
RE: Can't update or install software - by bcnaz - 11-23-2021, 07:16 PM
RE: Can't update or install software - by P3TER - 12-26-2021, 04:49 PM
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,306 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 820 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,985 10-15-2023, 10:12 PM
  PPKB certain keys not working after kernel update ragreenburg 20 13,158 06-11-2023, 03:19 AM
Last Post: lectrode
  unable to install applications dln949 5 1,564 06-08-2023, 08:38 PM
Last Post: Conjada
  satellite doesn't work after update shulamy 1 902 05-17-2023, 10:34 PM
  Latest update broke my install user641 8 3,784 02-22-2023, 05:54 AM
Last Post: gregb49
  new to pacman. Trying to install VIM, getting a 404 when it tries to download. willyray 1 1,182 12-24-2022, 11:00 PM
Last Post: shulamy
  Waydroid on Arch Linux ARM install guide? tk1107 3 5,640 10-08-2022, 07:46 AM
Last Post: PineFone
  Help to execute script to install arch with FDE user641 5 3,579 07-03-2022, 09:25 PM
Last Post: RTP
