Can't update or install software
(09-23-2021, 11:50 PM)kqlnut Wrote: The mirror where pacman gets its data from seems to be unavailable. Check out this article on mirrors and try another one.
Thanks! I read the article but it's a little over my head, still new to this stuff. I tried to ping mirror.archlinuxarm.org and it seems to be working:
sudo ping mirror.archlinuxarm.org
64 bytes from archlinuxarm.org (50.116.36.11
0):icmp_seq=220 ttl=49 time=86.4 ms
The first error I observed was on the initial boot script when it was "Generating pacman keyring master key" and failed, and it wasn't connected to the internet at the time since WiFi wasn't logged in yet, so the mirror wasn't part of the mix. I thought maybe it needs an internet connection on initial boot (although that wasn't in the instructions) so I reinstalled Arch, plugged the dock into it, and hardwired it to my router for the initial boot sequence, but it didn't change anything. And I saw the same error message come up when I was installing the July build too. The fact that nobody else seems to have this problem makes me wonder if it's something about what I'm doing on my end. I'm using ZorinOS 15, Jumpdrive (Pine64-Pinephone.img.xz), and the stock "Repair Disk Image" utility (which I used to install Manjaro/Plasma with no problems). I wonder if using Windows 10 with BalenaEtcher would have different results.
If it doesn't have a "pacman keyring master key," that would interfere with the operation of pacman, wouldn't it? Is there a command line to redo "Generating pacman keyring master key"?
Can't update or install software - by P3TER - 09-23-2021, 08:17 PM
RE: Can't update or install software - by bcnaz - 09-23-2021, 11:31 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 01:51 AM
RE: Can't update or install software - by bcnaz - 09-24-2021, 08:46 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 09:38 PM
RE: Can't update or install software - by bcnaz - 09-24-2021, 09:48 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 10:00 PM
RE: Can't update or install software - by kqlnut - 09-25-2021, 03:05 AM
RE: Can't update or install software - by kqlnut - 09-23-2021, 11:50 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 04:09 AM
RE: Can't update or install software - by kqlnut - 09-24-2021, 10:30 AM
RE: Can't update or install software - by bcnaz - 09-23-2021, 11:56 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 02:10 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 05:33 PM
RE: Can't update or install software - by kqlnut - 09-24-2021, 06:48 PM
RE: Can't update or install software - by bcnaz - 09-25-2021, 02:17 AM
RE: Can't update or install software - by P3TER - 09-25-2021, 04:03 AM
RE: Can't update or install software - by bcnaz - 09-25-2021, 12:40 PM
RE: Can't update or install software - by P3TER - 09-26-2021, 01:04 AM
RE: Can't update or install software - by bcnaz - 09-26-2021, 03:43 PM
RE: Can't update or install software - by P3TER - 09-26-2021, 05:14 PM
RE: Can't update or install software - by kqlnut - 09-27-2021, 02:19 AM
RE: Can't update or install software - by bcnaz - 11-23-2021, 07:16 PM
RE: Can't update or install software - by P3TER - 12-26-2021, 04:49 PM
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,342 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 843 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 2,013 10-15-2023, 10:12 PM
  PPKB certain keys not working after kernel update ragreenburg 20 13,272 06-11-2023, 03:19 AM
Last Post: lectrode
  unable to install applications dln949 5 1,589 06-08-2023, 08:38 PM
Last Post: Conjada
  satellite doesn't work after update shulamy 1 911 05-17-2023, 10:34 PM
  Latest update broke my install user641 8 3,836 02-22-2023, 05:54 AM
Last Post: gregb49
  new to pacman. Trying to install VIM, getting a 404 when it tries to download. willyray 1 1,195 12-24-2022, 11:00 PM
Last Post: shulamy
  Waydroid on Arch Linux ARM install guide? tk1107 3 5,667 10-08-2022, 07:46 AM
Last Post: PineFone
  Help to execute script to install arch with FDE user641 5 3,618 07-03-2022, 09:25 PM
Last Post: RTP
