Please help...Pinebook Pro Night Color / mode not working :(
Thanks, but I tried this already (uncommented WaylandEnable=true). After reboot, I do not see any option to select gnome+wayland on the login screen. Only options are Gnome, Gnome Classis, and KDE (X11).
After logon, when I run
echo $XDG_SESSION_TYPE
the output is X11. Also,  Night light/Mode does not work.
I also tried to install gnome-session-wayland using below command but received error, "target not found".
sudo pacman -Syu gnome-session-wayland
further I enabled debug (debug=true in  custom.conf). Here is the output of failed messages. Appreciate any help resolving the issue regarding gnome+wayland.
[sushil@pbp ~]$ journalctl -b | grep fail | grep gnome
Jul 31 16:12:14 pbp gnome-session[950]: gnome-session-binary[950]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:12:14 pbp gnome-session-binary[950]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:12:15 pbp gnome-shell[974]: g_hash_table_destroy: assertion 'hash_table != NULL' failed
Jul 31 16:12:20 pbp gnome-shell[974]: meta_drm_buffer_gbm_new_lock_front failed: drmModeAddFB2WithModifiers failed: Invalid argument
Jul 31 16:12:20 pbp org.gnome.Shell.desktop[974]: mutter:ERROR:../mutter/src/backends/native/meta-onscreen-native.c:204:meta_onscreen_native_notify_frame_complete: assertion failed: (!cogl_onscreen_peek_head_frame_info (onscreen))
Jul 31 16:12:20 pbp org.gnome.Shell.desktop[974]: Bail out! mutter:ERROR:../mutter/src/backends/native/meta-onscreen-native.c:204:meta_onscreen_native_notify_frame_complete: assertion failed: (!cogl_onscreen_peek_head_frame_info (onscreen))
Jul 31 16:12:25 pbp org.gnome.Shell.desktop[996]: (EE) failed to read Wayland events: Connection reset by peer
Jul 31 16:12:25 pbp gnome-session-binary[950]: Unrecoverable failure in required component org.gnome.Shell.desktop
Jul 31 16:12:28 pbp gnome-session[1238]: gnome-session-binary[1238]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:12:28 pbp gnome-session-binary[1238]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:12:50 pbp audit[1499]: USER_AUTH pid=1499 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:12:50 pbp kernel: audit: type=1100 audit(1627773170.230:152): pid=1499 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:12:50 pbp audit[1499]: CRED_ACQ pid=1499 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:12:50 pbp kernel: audit: type=1103 audit(1627773170.250:154): pid=1499 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:13:06 pbp gnome-software[1871]: Failed to load /usr/lib/gnome-software/plugins-16/libgs_plugin_malcontent.so: failed to open plugin /usr/lib/gnome-software/plugins-16/libgs_plugin_malcontent.so: libmalcontent-0.so.0: cannot open shared object file: No such file or directory
Jul 31 16:13:09 pbp gnome-software[1871]: gs_app_add_icon: assertion 'G_IS_ICON (icon)' failed
Jul 31 16:13:10 pbp gnome-software[1871]: gs_app_add_icon: assertion 'G_IS_ICON (icon)' failed
Jul 31 16:31:25 pbp audit[5088]: USER_AUTH pid=5088 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:31:25 pbp kernel: audit: type=1100 audit(1627774285.158:207): pid=5088 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:31:25 pbp audit[5088]: CRED_REFR pid=5088 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:31:25 pbp kernel: audit: type=1110 audit(1627774285.178:209): pid=5088 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:40:49 pbp audit[1499]: CRED_DISP pid=1499 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty2 res=success'
Jul 31 16:40:49 pbp kernel: audit: type=1104 audit(1627774849.525:267): pid=1499 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty2 res=success'
Jul 31 16:40:51 pbp gnome-session[6816]: gnome-session-binary[6816]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:40:51 pbp gnome-session-binary[6816]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:40:51 pbp gnome-shell[6824]: g_hash_table_destroy: assertion 'hash_table != NULL' failed
Jul 31 16:40:55 pbp gnome-shell[6824]: meta_drm_buffer_gbm_new_lock_front failed: drmModeAddFB2WithModifiers failed: Invalid argument
Jul 31 16:40:55 pbp org.gnome.Shell.desktop[6824]: mutter:ERROR:../mutter/src/backends/native/meta-onscreen-native.c:204:meta_onscreen_native_notify_frame_complete: assertion failed: (!cogl_onscreen_peek_head_frame_info (onscreen))
Jul 31 16:40:55 pbp org.gnome.Shell.desktop[6824]: Bail out! mutter:ERROR:../mutter/src/backends/native/meta-onscreen-native.c:204:meta_onscreen_native_notify_frame_complete: assertion failed: (!cogl_onscreen_peek_head_frame_info (onscreen))
Jul 31 16:41:00 pbp org.gnome.Shell.desktop[6847]: (EE) failed to read Wayland events: Broken pipe
Jul 31 16:41:00 pbp /usr/lib/gdm-wayland-session[6815]: dbus-daemon[6815]: [session uid=120 pid=6815] Activated service 'org.gnome.Shell.Screencast' failed: Process org.gnome.Shell.Screencast exited with status 1
Jul 31 16:41:00 pbp gnome-session-binary[6816]: Unrecoverable failure in required component org.gnome.Shell.desktop
Jul 31 16:41:02 pbp gnome-session[7078]: gnome-session-binary[7078]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:41:02 pbp gnome-session-binary[7078]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Jul 31 16:41:22 pbp audit[7320]: USER_AUTH pid=7320 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:41:22 pbp kernel: audit: type=1100 audit(1627774882.185:308): pid=7320 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:41:22 pbp audit[7320]: CRED_ACQ pid=7320 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:41:22 pbp kernel: audit: type=1103 audit(1627774882.205:310): pid=7320 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="sushil" exe="/usr/lib/gdm-session-worker" hostname=pbp addr=? terminal=/dev/tty1 res=success'
Jul 31 16:41:36 pbp gnome-software[7677]: Failed to load /usr/lib/gnome-software/plugins-16/libgs_plugin_malcontent.so: failed to open plugin /usr/lib/gnome-software/plugins-16/libgs_plugin_malcontent.so: libmalcontent-0.so.0: cannot open shared object file: No such file or directory
Jul 31 16:41:39 pbp gnome-software[7677]: gs_app_add_icon: assertion 'G_IS_ICON (icon)' failed
Jul 31 16:41:40 pbp gnome-software[7677]: gs_app_add_icon: assertion 'G_IS_ICON (icon)' failed
Jul 31 16:41:49 pbp gnome-documents[7889]: g_irepository_find_by_name: assertion 'typelib != NULL' failed
RE: Please help...Pinebook Pro Night Color / mode not working :( - by sushilsharma71@gmail.com - 07-31-2021, 06:00 PM
  Debian on Pinebook Pro u974615 7 1,383 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,858 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,251 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,353 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,153 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,396 11-23-2023, 07:37 AM
  USB 3 port not working with Armbian zaius 3 932 11-13-2023, 01:54 PM
Last Post: zaius
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,536 08-31-2023, 04:20 PM
Last Post: TRS-80
  Camera not working with Cheese cypresstwist 1 1,276 08-18-2023, 02:02 AM
Last Post: juliamenendez
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,582 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
