Replacement scissor switches (ANSI keyboard)?
Is it possible to purchase replacement "scissor switch" mechanisms for the PBP keyboard (ANSI layout, if it matters)? These are the two tiny pieces of white plastic under each keycap.  They're not actually a switch, they are what holds the key in place while allowing it to move up and down.  I foolishly decided to rearrange the keycaps on my PBP to match a nonstandard layout, and now I have two keys that want to fall off because I broke their scissors.   I don't see this in the replacement parts section of the storefront, short of buying an entire keyboard, which seems wasteful.
Replacement scissor switches (ANSI keyboard)? - by zackw - 07-19-2021, 07:45 AM
  Bad replacement battery? chris88233 3 394 02-19-2024, 04:59 PM
  Replacement main board for Developers mozes 10 1,776 11-27-2023, 04:14 AM
Last Post: mozes
  Replacement battery for PineBook Pro DrYak 3 1,086 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 2,895 09-26-2023, 01:08 AM
Last Post: david-lechner
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,203 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 712 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 1,118 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 2,687 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 6,486 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 1,335 11-29-2021, 01:55 PM
Last Post: stozi
