Automatic Brightness Stuck On
(04-05-2022, 04:26 AM)biketool Wrote:
(04-04-2022, 05:13 PM)henrythemouse Wrote: Did you ever get this resolved? I'm having the same issue.
It has been a maybe six months and I did fix the problem, but I think I either had a wipe and reload or I found a fix to force it back to normal, maybe editing a config file.
Since then I have not tried to toggle it, post if you find a solution to the problem.
Honestly I think the new install when I got my 3/32 upgrade board happened though I feel like I found a fix that worked directly.
I tried to toggle it just now and it didn't' work correctly, it still seems to have the same issue, switch toggled but no blue in the 'switch' to indicate it did anything, I am surprised that it didn't get fixed since last year considering all of the great work that has been done to Mobian.
My solution was to use dconf-editor to change the setting in /org/gnome/settings-daemon/plugins/power/ambient-enabled to false. But the toggle is still not functional in the settings app.
Automatic Brightness Stuck On - by biketool - 06-25-2021, 04:01 AM
RE: Automatic Brightness Stuck On - by biketool - 04-05-2022, 04:26 AM
RE: Automatic Brightness Stuck On - by henrythemouse - 04-05-2022, 11:49 AM
  boot gets stuck shortly after disk decryption vortex 8 4,150 02-13-2023, 02:11 AM
Last Post: sharase
  Stuck with 1234 tcoulon 2 1,315 08-06-2022, 01:20 AM
Last Post: tcoulon
  Disable *automatic* on-screen keyboard iwakura_lain 0 962 06-11-2022, 09:49 AM
Last Post: iwakura_lain
  How to do automatic login or shorten the login number amosbatto 0 1,044 12-08-2021, 09:29 PM
Last Post: amosbatto
  Anyone find a work around for the brightness issues from kernels 5.13/14? ragreenburg 2 2,443 09-01-2021, 08:49 AM
Last Post: ragreenburg
  Anyway to set up automatic backups? AwHereWeGoAgain 1 2,024 06-21-2021, 02:40 AM
Last Post: evilbunny
  Unable to turn off auto brightness at times motox6 0 1,299 05-05-2021, 07:56 PM
Last Post: motox6
  Run Mobian Unstable without risking being stuck without a working phone C0ffeeFreak 3 4,236 04-23-2021, 01:10 PM
Last Post: RTP
  apt dist-upgrade stuck Concrete_panda 3 5,060 08-05-2020, 06:05 AM
Last Post: antiX-Dave
  Automatic app scaling a-wai 14 16,287 07-30-2020, 04:07 PM
Last Post: arturo2bodegas
