Run Mobian Unstable without risking being stuck without a working phone
If you follow the Mobian blog you may know there is an unstable branch now for those who want to test the cutting edge.
https://blog.mobian-project.org/posts/20...le-distro/
Some of you may be afraid to switch because you needs your phones to work and can't take the risk of something unstable upsetting that.
You can have your cake and eat it too. You can clone your drive via Balena Etcher onto an SD card or create an ISO image of it (back up) using Disks in Linux and burn it to an SD card. Even an encrypted drive. You should have a back up anyway. Use Jumpdrive on an SD to allow your computer to see the Emmc and don't decrypt it before cloning. Then you can use the SD card image for unstable and leave the Emmc alone. If things break you can just remove the SD card and still have a working phone in a pinch just by removing it. Make a change in the order of your favorite apps so you know what you are booted into. (exaple, put your phone on the left on the SD card image) The reason why is sometimes after an update on the Emmc your phone will only boot to the newer boot Image (the Emmc) but you can over ride that temporarily because some type of temporary FEL mode must be activated. Power and volume down will boot back into the SD card. Power and volume up will boot into the Emmc until the next update on the SD card. Then it will be normal boot priority with the SD card.
What's the verdict so far? Any differences from "stable"?
(03-15-2021, 04:09 PM)zborgerd Wrote: What's the verdict so far? Any differences from "stable"?
Phosh seems more fluid and responsive in the unstable. It's a newer version. The suspend/LTE data loss forcing a reboot got patched in the unstable the day before it made it to the stable. More apps to choose from in software but a lot don't work. Other then that I really haven't noticed anything else.
(03-15-2021, 09:58 AM)C0ffeeFreak Wrote: If you follow the Mobian blog you may know there is an unstable branch now for those who want to test the cutting edge.
Or if you have a Linux laptop/desktop, throw in a Jumpdrive sdcard and use lsblk/dmesg to find the emmc and dd to copy and even restore the backup.
Then run (from laptop hooked to Jumpdrive booted phone):
sudo dd if=/dev/EMMClocation of=Mobian-backup.img bs=12M status=progress
Then use Jumpdrive once again (reverse the if/of option values) to put right back on your emmc if something goes wrong Smile
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,516 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 70 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Mobile internet via cellular network mostly not working Anna 18 9,723 01-19-2024, 02:59 AM
Exclamation The internal speaker stops working anonymous 6 814 01-17-2024, 05:53 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,717 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,689 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 581 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,541 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,799 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 577 07-05-2023, 03:57 AM
Last Post: paulcarton
