Stuck with 1234
Hi back,
These last month I was stuck with a Pinephone Pro not working (Manjaro would not update and could not connect to my phone company...)
Today I lokked at it again, installed Tow-boot and flashed Mobian instead - and made my first call.
So far, so good. The funny thing is I can't change Mobian's password (at least from GUI). Whatever i try, the password is not accepted. Should I do this from the command line? Sudo passwd <user>?
Thierry
You don't even need root privileges to change your own password: 'passwd' is enough.
Thank you, worked. I now have set a root password too. Now with the PinePhone keyboard it's a nano computer...
The keyboard is lacking a -/_ key however, have to combine with the onscreen keyboard. Luckily shutdown now workd.
  boot gets stuck shortly after disk decryption vortex 8 4,043 02-13-2023, 02:11 AM
Last Post: sharase
  Automatic Brightness Stuck On biketool 3 2,560 04-05-2022, 11:49 AM
Last Post: henrythemouse
  Run Mobian Unstable without risking being stuck without a working phone C0ffeeFreak 3 4,179 04-23-2021, 01:10 PM
Last Post: RTP
  apt dist-upgrade stuck Concrete_panda 3 5,010 08-05-2020, 06:05 AM
Last Post: antiX-Dave
  Mobian stuck in bootloop The_Bolder 3 5,302 06-25-2020, 01:16 PM
Last Post: The_Bolder
