briicked, fix from MASKROM mode?
luckily your pbp isn't really bricked, and can be salvaged/restored.
when you turned off the emmc to boot from SD, did your try pressing the RESET button (28) and trying to boot from SD again?
Have you tried any other live images on your SD?
Once you do get an SD img to boot, flip the emmc switch back and run the commands in this section to bind your emmc again, and be able to edit/write to it: https://wiki.pine64.org/index.php/Pinebo...nformation
RE: briicked, fix from MASKROM mode? - by tophneal - 05-20-2021, 12:28 PM
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 1 992 10-30-2022, 10:09 AM
  Manjaro ARM new version? And hibernate/ sleep mode regretfulpineuser 0 935 06-20-2022, 02:48 PM
Last Post: regretfulpineuser
  How to get sleep mode without bricking? regretfulpineuser 0 853 06-10-2022, 12:31 AM
  cannot boot SD card : "unable to select a mode" alchemist 0 2,155 06-18-2021, 02:03 AM
Last Post: alchemist
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,823 01-17-2021, 01:50 PM
Last Post: BananaPekan
