Need to re-write U-boot from Pinephone pro currently in mass rom mode
Hi All;
I was trying to flash my emmc on Pinephone Pro and by mistake I erased instead my U-boot. I used an sd-card for the day and once the battery was drained the phone went into mass rom mode and I can no longer power it on.
After recharging the battery from a power station I tried to switch it on unsuccessfully. I tried as well the recovery mode (using the RE button on the back and it would work).
I can no longer see the device when running the lsblk command. However I see the rockship in mass rom mode when I run the lsusb command from my linux labtop.
I read few instruction and a script provided by the rkdeveloptool-master to flash the memory and see if I can copy across a new bin file (rk3399_loader_spinor_v1.15.114.bin) and from there being able to move out of the mass rom mode and use again the sd card. It was not successful.
I was wondering if there is U-boot image available that I can use and how can I copy it across to my phone memory since I am still on mass rom mode. I guess there are 2 questions in 1:
a) how to move out of the mass rom mode
b) How to reinstall the Uboot in my Pinephone Pro
Thank you.
You are in wrong forum section,,
this is pineBOOKpro,, go down (in forum) to pine PHONE section
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,289 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,884 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,070 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,379 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,825 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,538 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,915 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,637 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 9,643 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,923 01-16-2024, 09:17 AM
Last Post: jbradley419
