cannot boot SD card : "unable to select a mode"
Hi!
I have U-Boot installed on SPI and Gentoo Linux running on eMMC.
I would like to be able to boot from SD card for maintenance purposes.
The boot order is this by default :
altbootcmd=setenv boot_syslinux_conf extlinux/extlinux-rollback.conf;run distro_bootcmd boot_scripts=boot.scr.uimg boot.scrboot_syslinux_conf=extlinux/extlinux.conf boot_targets=mmc1 mmc0 nvme0 usb0 pxe dhcp sf0 bootcmd=run distro_bootcmd distro_bootcmd=setenv nvme_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done
So it should be: sd card, eMMC, nvme, usb, pxe, ...
but when I boot, U-Boot try to initilize the SD card and fails "unable to select a mode", then continues to eMMC:
The system is going down for reboot NOW! pbp ~ # U-Boot TPL 2020.07-pcm720-00007-g132da38490 (Jul 20 2020 - 20:40:04) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.07-pcm720-00007-g132da38490 (Jul 20 2020 - 20:40:04 +0300) Trying to boot from SPI NOTICE:  BL31: v2.3(release):v2.3-353-gae72c4d5e NOTICE:  BL31: Built : 20:39:57, Jul 20 2020 U-Boot 2020.07-pcm720-00007-g132da38490 (Jul 20 2020 - 20:40:04 +0300) SoC: Rockchip rk3399 Reset cause: RST Model: Pine64 Pinebook Pro DRAM:  3.9 GiB PMIC:  RK808 MMC:  mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 In:    serial Out:  serial Err:  serial Model: Pine64 Pinebook Pro Net:  No ethernet found. Hit any key to stop autoboot:  0 unable to select a mode switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 651 bytes read in 18 ms (35.2 KiB/s) ## Executing script at 00500000 =========================== === GENTOO LINUX (eMMC) === =========================== Boot script loaded from mmc 0 25088512 bytes read in 1104 ms (21.7 MiB/s) 61463 bytes read in 22 ms (2.7 MiB/s) ## Flattened Device Tree blob at 01f00000   Booting using the fdt blob at 0x1f00000   Loading Device Tree to 00000000f4e8c000, end 00000000f4f03fff ... OK Starting kernel ... pbp login:
I've tried many different OS : manjaro, dietpi, and same result:
=> mmc dev 1 unable to select a mode ==== unplug SD card ; replug it => mmc dev 1                  switch to partitions #0, OK mmc1 is current device => mmc part Partition Map for MMC device 1  --  Partition Type: DOS Part Start Sector Num Sectors UUID Type ** Can't read partition table on 1:0 **
but Linux can read the SD card and the contents. The partition table is MBR, boot partition 1 is in FAT or EXT2 and marked as active.
I will try an other SD card...
SOLVED: I change the SD card and now it boots first on it, then the eMMC.
Kind regards,
Xavier Miller.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,268 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,860 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,025 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,343 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,815 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,528 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Unable to use umlaut key combos ili 4 5,932 12-02-2024, 03:56 PM
  Cant boot into an OS trashtendenz 3 5,908 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,627 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 9,616 01-19-2024, 02:29 PM
