PWM whine near earpiece in low signal phone call and loud sound sent to the other end
(05-24-2021, 03:31 AM)vortex Wrote: I tried recording sound while downloading a large file over 2 G (needed to be slow and bandwidth heavy) and it didn't work. Problem is, when downloading, the transmit power is only very intermittently high and when it pulses high, there is an audible sound (probably from a capacitor charging) that is extremely broadband that limits the ability to pick anything else up.
How about trying to upload a large file under the same network circumstances?  A large file upload should crank the modem's transmit power to the max, and keep it at that level for as long as the upload keeps going.  It should even suffice to run "speedtest-cli --no-download --server <id>" (maybe with the "--single" flag as well) on the phone in a simple "for" loop, so you don't have to search for a fast server that accepts large file uploads.
(05-24-2021, 03:31 AM)vortex Wrote: With the way the sound is configured, I think it should be possible to run the recorder while doing a phone call (which has high upload and high and stable transmit power). I will see how that goes.
It should be possible. As far as I can see, you should pass "-2" together with other relevant flags to Ondrej's audio setup utility, to activate the modem's digital audio interface while enabling the "usual" audio input and output as well, i.e. the earpiece and the microphone.  In other words, that should be a pretty much regular phone call, which could also be placed using the regular dialer application.
(05-24-2021, 03:31 AM)vortex Wrote: Looking at the code, you are right, -2 is what to use. Thank you.
You're welcome.  Thank you for doing all this testing in the first place!
RE: PWM whine near earpiece in low signal phone call and loud sound sent to the other end - by dsimic - 05-24-2021, 04:04 AM
  Phone powers off with high user demands car46999 7 718 04-11-2024, 09:17 AM
Last Post: zetabeta
  Phone will not turn on (but sometimes will) insidetrip101 10 4,963 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 1,115 07-31-2023, 07:50 PM
  No calls on Pine Phone Beta convergence edition polypode 1 1,215 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,165 02-20-2023, 12:14 AM
  I cannot call or receive calls aka0kuro 6 3,199 01-13-2023, 05:31 PM
Last Post: alaraajavamma
Thumbs Down Phone is unresponsive theneedful 14 7,913 08-12-2022, 08:18 AM
Last Post: theneedful
  Phone Dead Already? MarsColonist 4 2,759 08-11-2022, 11:52 AM
Last Post: auanta
  PPKB with phone; phone dies while charging SwordfishII 1 1,407 06-08-2022, 04:14 AM
Last Post: SwordfishII
  Lost internal earpiece Veraendert 3 2,435 02-14-2022, 07:51 AM
Last Post: Veraendert
