Battery mot charging past 54%
(05-15-2021, 05:16 PM)StickyPine Wrote: Hello,
I juste got the PinePhone but the battery does not seem to be charging past 54%.
I saw on the wiki that some OS' limit the maximum charging percentage in order to improve the longevity of the battery. Because I'm having this issue on different OS' it got me thinking that it is a hardware problem, but it might not be.
Is it a known issue ? What can I do about it ?
Many thanks !
 I had the same issue, both with the Mobian and Beta versions, but I solved it by placing the charger directly to an outlat and let it charge for 10+ hours or until it showed 90+% charge. I also interchanged the batteries between both pinephone versions and charged as above. No more batteries issues.
Battery mot charging past 54% - by StickyPine - 05-15-2021, 05:16 PM
RE: Battery mot charging past 54% - by dsimic - 05-16-2021, 06:35 AM
RE: Battery mot charging past 54% - by StickyPine - 05-16-2021, 10:58 AM
RE: Battery mot charging past 54% - by marcih - 05-16-2021, 12:30 PM
RE: Battery mot charging past 54% - by dsimic - 05-16-2021, 12:30 PM
RE: Battery mot charging past 54% - by 8bit - 05-16-2021, 08:06 AM
RE: Battery mot charging past 54% - by dsimic - 05-16-2021, 08:27 AM
RE: Battery mot charging past 54% - by 8bit - 05-16-2021, 09:14 AM
RE: Battery mot charging past 54% - by dsimic - 05-16-2021, 09:38 AM
RE: Battery mot charging past 54% - by StickyPine - 05-16-2021, 02:57 PM
RE: Battery mot charging past 54% - by StickyPine - 05-17-2021, 02:32 AM
RE: Battery mot charging past 54% - by dsimic - 05-17-2021, 09:34 AM
RE: Battery mot charging past 54% - by dsimic - 07-28-2021, 06:08 AM
RE: Battery mot charging past 54% - by bcnaz - 07-28-2021, 08:09 AM
RE: Battery mot charging past 54% - by evilbunny - 05-18-2021, 07:52 AM
RE: Battery mot charging past 54% - by Xzska-collab - 06-29-2021, 09:42 AM
RE: Battery mot charging past 54% - by dsimic - 07-07-2021, 08:15 PM
RE: Battery mot charging past 54% - by biketool - 06-30-2021, 05:59 AM
RE: Battery mot charging past 54% - by bcnaz - 07-26-2021, 03:47 AM
RE: Battery mot charging past 54% - by megous - 09-18-2021, 09:16 PM
RE: Battery mot charging past 54% - by Ppuser77 - 11-19-2021, 06:00 AM
RE: Battery mot charging past 54% - by Jack Kim - 07-27-2021, 03:57 AM
RE: Battery mot charging past 54% - by Ppuser77 - 11-24-2021, 05:06 AM
RE: Battery mot charging past 54% - by bcnaz - 11-24-2021, 07:04 PM
RE: Battery mot charging past 54% - by vusra - 01-14-2022, 04:49 AM
RE: Battery mot charging past 54% - by kqlnut - 01-14-2022, 08:29 AM
RE: Battery mot charging past 54% - by vusra - 02-25-2022, 12:47 AM
RE: Battery mot charging past 54% - by bcnaz - 02-26-2022, 12:01 AM
RE: Battery mot charging past 54% - by vusra - 01-14-2022, 04:01 PM
RE: Battery mot charging past 54% - by kqlnut - 01-14-2022, 05:13 PM
RE: Battery mot charging past 54% - by vusra - 02-26-2022, 02:07 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 607 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 3,500 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,584 03-20-2023, 12:54 AM
Last Post: bcoyle
  Charging Indicator On - Not Charging SJSEng 0 806 08-30-2022, 07:33 AM
Last Post: SJSEng
  Power supply vs battery albafrati 11 4,811 06-22-2022, 06:04 PM
Last Post: albafrati
  PPKB with phone; phone dies while charging SwordfishII 1 1,408 06-08-2022, 04:14 AM
Last Post: SwordfishII
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 1,500 04-28-2022, 12:45 PM
Last Post: james8880
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 4,123 03-08-2022, 12:25 PM
Last Post: jopple
  Battery replacement alternative sax1960 7 6,444 08-29-2021, 07:03 AM
Last Post: bcnaz
  Battery Capacity and Software Interaction food 2 2,482 08-15-2021, 07:19 AM
Last Post: bcnaz
