Touchpad notchy on new 2021 pinebook pro
Hi all,
I read this and OP's post was exactly what I was experiencing on my new pinebook pro (rcvd 4/2021).  But I have found the cause of the issue, and it's just a setting.  Once the touchpad settings were changed from stock I have found it completely usable, not the best touchpad ever, but not the headache that it was before.  This is especially true since the smaller screen size made getting the cursor from close to the thing you wanted to click, onto that thing.  You couldn't just move a little, you would move and nothing would happen, then it would finally move and jump past your target.  So the setting in question is found in manjaro by going to  start button>system settings>input devices>touchpad then to the pointer motion tab.  The setting in question is the noise cancellation, I think by default it was set to 8 for vertical and horizontal.  Not sure of the specifics, but basically you could select 8 units of movement before the cursor would move, causing great frustration.  I changed both settings to 0, which made a vast improvement.  I also slowed down the cursor having minimum speed at about 75% of the way to the first notch, maximum speed 25% past the second notch, and and acceleration 25% past the first notch.  Change the settings, click apply at the bottom right and breathe a sigh of relief.
Hope this helps, possibly the defaults can be adjusted for when new systems are shipped they won't have this problem.
BCB
RE: Touchpad notchy on new 2021 pinebook pro - by BCB - 05-30-2021, 04:04 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 803 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 385 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 328 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 671 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,191 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 132,292 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,183 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,598 12-27-2022, 03:31 PM
Last Post: samtux
  Touchpad Issues - August 2022 Run SteveCaruso 5 3,069 12-14-2022, 11:00 PM
Last Post: doug
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 138,732 11-30-2022, 04:28 PM
