Bluetooth keyboard with trackpad
(05-10-2021, 04:39 PM)Zebulon Walton Wrote:
(05-10-2021, 09:39 AM)wibble Wrote: If the trackpad is anything like the one on the Rii mini i8 (not bluetooth but similarly small) it will be frustrating to use - a trackpoint would be much better, or a larger touch surface on the back of the keyboard. Not sure if anyone makes one with either of those though. Being Bluetooth 3.0 it should be fine so long as they've not gone for nonstandard quirks.
I received the keyboard today and it actually works quite well. No problem connecting to the Pinephone's built-in bluetooth. Touchpad action isn't bad considering the small size. Obviously on a small keyboard like this you won't be writing any novels but it's a heck of a lot better than the on-screen keyboard for using the terminal. About the only downside I see is with bluetooth enabled on the Pinephone battery life will be shorter.
Zebulon Walton, are you still happy with the keyboard? I tested your keyboard with PMOS, it always disconnected. So I decided for the PinePhone keyboard. Wibble published some interestesting tests about the iGo Stowaway bluetooth keyboard here:
https://forum.pine64.org/showthread.php?tid=16449
RE: Bluetooth keyboard with trackpad - by wibble - 05-09-2021, 09:22 AM
RE: Bluetooth keyboard with trackpad - by wibble - 05-10-2021, 09:39 AM
RE: Bluetooth keyboard with trackpad - by Peter Gamma - 06-17-2022, 12:47 PM
RE: Bluetooth keyboard with trackpad - by wibble - 05-12-2021, 07:28 AM
  keyboard case charging but not typing new2pinephone 18 5,781 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,524 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 424 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,170 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 450 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,232 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 515 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 615 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,021 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 828 10-11-2023, 09:03 AM
Last Post: elof
