Arch Linux PinePhone scaling slider
(05-08-2021, 02:00 AM)arcanemachine Wrote:
(05-05-2021, 01:08 PM)Chief Wrote: Greeting to all,
I'm a newbie at this forum stuff.
I suggest for Arch Linux ARM on PinePhone for the community to create a slider for scaling.
The slider could be located under the volume-brightness sliders. I see that a 100% / 200% scaling has been created in settings / Display which is great but if there were graduations at least of say 10% that would be perfect. This could solve several issues with apps in the software community as each app can be custom set and thereby much easier to use.
This would be a request you would probably want to make to Phosh (the graphical shell), not Arch.
All the distros mostly just bundle up existing software, and add minor tweaks behind the scenes.
If you want, here's a link to a script/.desktop file that gives you an easy way to choose your display scaling. You can configure it to show up in your list of installed apps:
https://source.puri.sm/librem5-apps/libr...the-screen
https://source.puri.sm/librem5-apps/libr...en.desktop
Hi again ... I have tried a couple of options to optimize scaling and have managed to scale certain apps (Evolution) but I would like to know how to implement this script in your link? I copied the script to a text file and I see the graduated scaling which would be fine.
Arch Linux PinePhone scaling slider - by Chief - 05-05-2021, 01:08 PM
RE: Arch Linux PinePhone scaling slider - by Chief - 05-31-2021, 08:27 PM
  Updating Arch Linux _radv_ 8 993 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,403 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 883 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 2,077 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,943 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 967 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 879 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,209 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 2,537 10-23-2022, 01:53 PM
Last Post: Chief
  Evolution no longer runs on Arch Phosh. Chief 2 1,469 10-17-2022, 07:22 AM
Last Post: Chief
