Cellular Data, Mobian - "No WWAN Adapter Found"
Have you tried to toggle the hardware switch for the modem (switch #1)?
If that does not work the next thing I would try is to flash an OS to a uSD and boot from it to see if it recognizes the modem.
If it still is not booting you may want to look at a firmware recovery method:
https://wiki.pine64.org/wiki/PineModems#...e_Recovery
(There are 2 ways to unlock the bootloader, I recommend shorting the pins rather than the ADB method but it depends on what's easiest for you.)
https://github.com/Biktorgj/quectel_eg25...ery#readme
I broke my modem's firmware a while back and managed a reasonable recovery using Biktorgj's procedure. Wink
Cheers!
RE: Cellular Data, Mobian - "No WWAN Adapter Found" - by MtnSk8 - 05-03-2021, 01:44 PM
Exclamation No wIfI after Mobian update crakabeats 4 2,192 1 hour ago
Last Post: 98cwitr
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,140 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 18,086 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  how to backup user data? Uturn 1 709 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 3,337 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US cellular service (as I understand it as of post date) freebsd 17 9,546 07-23-2023, 04:57 PM
Last Post: kb-zealot
  No sound after Mobian upgrade arbocenc 1 796 11-28-2022, 11:02 AM
Last Post: arbocenc
  cell data and MMS on AT+T prepaid ossands 2 1,509 10-13-2022, 07:28 AM
Last Post: ossands
  pinephone-support package not upgradable on Mobian fhireman 4 2,438 09-24-2022, 08:01 AM
Last Post: dante404
  Cannot Remove SIM Adapter CheeseEBoi 1 1,137 07-09-2022, 04:07 PM
Last Post: mcjonmor
