GPS Antenna - external connector?
Thanks @8bit, much appreciated.
I haven't been able to try the alternate signal path (my soldering skills aren't good enough), but I have acquired a ublox7 GPS dongle which is giving good enough results for my purposes.
Cheers!
GPS Antenna - external connector? - by GregH - 04-20-2021, 06:01 PM
RE: GPS Antenna - external connector? - by GregH - 04-25-2021, 06:13 PM
RE: GPS Antenna - external connector? - by 8bit - 04-25-2021, 12:58 AM
RE: GPS Antenna - external connector? - by 8bit - 04-27-2021, 11:55 AM
RE: GPS Antenna - external connector? - by GregH - 05-03-2021, 05:30 PM
RE: GPS Antenna - external connector? - by 8bit - 05-03-2021, 07:14 PM
RE: GPS Antenna - external connector? - by GregH - 05-03-2021, 07:52 PM
RE: GPS Antenna - external connector? - by 8bit - 05-03-2021, 08:25 PM
RE: GPS Antenna - external connector? - by GregH - 05-04-2021, 12:18 AM
RE: GPS Antenna - external connector? - by 8bit - 05-04-2021, 10:04 AM
RE: GPS Antenna - external connector? - by 8bit - 05-04-2021, 12:51 PM
RE: GPS Antenna - external connector? - by GregH - 05-09-2021, 08:03 PM
RE: GPS Antenna - external connector? - by jack1 - 08-10-2021, 03:40 PM
  USB-C connector Overheated and melted nickbenjones 2 1,402 05-26-2023, 06:16 PM
  External Antenna port daily driver on Verizon Billthompson 6 4,092 04-30-2022, 09:51 PM
Last Post: TheBusyWizard
  Connect external modem? feklee 7 5,053 12-06-2021, 03:52 AM
Last Post: feklee
  Fragile SIM card connector hakkou 1 1,858 08-25-2021, 07:44 AM
Last Post: wibble
  USB C connector loose? bceverly 3 3,042 08-10-2021, 09:44 AM
Last Post: c3l@
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 2,189 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 2,862 02-23-2021, 06:28 AM
Last Post: scholbert
  external speaker mascarade01 5 8,832 12-16-2020, 07:32 AM
Last Post: mascarade01
  Main Board Swap: Camera connector problems tyha 5 4,804 11-19-2020, 06:25 PM
Last Post: pajux
  Wobbly USB-C connector? pregier 5 6,177 10-16-2020, 10:22 AM
Last Post: wibble
