Provide power in via Pi-2 header
I've got the jumper on my board set to DC 5v (pins 1&2) and if I try to back power it via the Pi-2 headers the Pine's power regulator gets *really hot* and after a few minutes the power to the CPU get's flakey and the CPU halts. Now, move the same power source over to the Euler bus and all works perfectly. I'm not using a battery on this system at all, so that's not part of the equation.
Interesting note, my power source utilizes a supervisory circuit to switch on the power going to the Pine and on the Pi-2 bus it senses something of a short and wont turn on. I can force it on, which is what I did to find that the Pine does not agree with the Pi-2 bus as power input.
Provide power in via Pi-2 header - by BenCranston - 06-13-2016, 07:55 PM
RE: Provide power in via Pi-2 header - by g_t_j - 06-14-2016, 06:14 AM
RE: Provide power in via Pi-2 header - by g_t_j - 06-15-2016, 05:17 AM
RE: Provide power in via Pi-2 header - by BenCranston - 12-29-2016, 11:34 AM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 02:23 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 03:03 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 04:26 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,105 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,593 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,532 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,363 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,828 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,370 03-18-2017, 09:18 AM
Last Post: Luke
  any danger from using 2 power sources at same time? dkryder 3 6,953 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,372 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,197 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 6,821 10-02-2016, 04:35 AM
Last Post: pfeerick
