Provide power in via Pi-2 header
I'm also trying to provide power to the Pine through the Pi-2 Bus, but as you can see in the schematics:
https://drive.google.com/file/d/0B0cEs0l...VrZHM/view
Pins 2 & 4 of the Pi-2 Bus are NOT power inputs, they are only outputs.
It's not the same in the Euler bus, as pins 2 & 4 are directly connected to the DCIN (and therefore to the microUSB) and can be used as power inputs.
Taking a look at the full schematics:
https://drive.google.com/file/d/0B0cEs0l...ItV2M/view
You can see that the DCIN is powering the PMIC and then I supose it is outputing this voltage through PS1 and PS2, that then goes to a MT3608 power regulator that finally is outputing 5V to the VCC-5V line, that powers the pins 2 & 4 of the Pi-2:
microUSB > [DCIN] > PMIC > [PS] > MT3608 > [VCC-5V] > Pi-2-GPIOs
The problem here is that there are a lot of Raspberry Pi hats designed to provide power through the 5v Pi-2 pins and they are not working for obvious reasons.
At this point I have a question, is there any possibility to short the VCC-5V and DCIN lines using the 5V and DCIN pins in the Euler Bus, so that the power from the 5V pins in the Pi-2 Bus powers the Pine 64 without frying something? My concern is that the voltage at the output and the input of the MT3608 could not be the same, and could generate uncontrolled currents flowing through the 5 volt lines. Am I right?
In this case, I'm a bit disappointed with the Pi-2 Bus design, as it was supposed to be used with Raspberry Pi Hats and this use-case has been not considered  Sad
Provide power in via Pi-2 header - by BenCranston - 06-13-2016, 07:55 PM
RE: Provide power in via Pi-2 header - by g_t_j - 06-14-2016, 06:14 AM
RE: Provide power in via Pi-2 header - by g_t_j - 06-15-2016, 05:17 AM
RE: Provide power in via Pi-2 header - by ciclopez - 12-11-2016, 11:59 AM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 02:23 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 03:03 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 04:26 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,110 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,601 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,536 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,374 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,848 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,373 03-18-2017, 09:18 AM
Last Post: Luke
  any danger from using 2 power sources at same time? dkryder 3 6,958 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,389 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,213 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 6,824 10-02-2016, 04:35 AM
Last Post: pfeerick
