Write to an A1-rated Micro SD card failed
The MMC driver in the Linux kernel uses the SWITCH (CMD6) command.  There are a few interesting C functions:
The slight trouble is that the results of the SWITCH (CMD6) command, in the current state of the MMC driver, are not directly available for debugging purposes.  Regarding the issue I've originally described in this thread, my current "suspect" is the sd_set_current_limit() function, which may not properly handle all possible cases, i.e. all combinations of the MMC host capabilities and the microSD card requirements.
RE: Write to an A1-rated Micro SD card failed - by dsimic - 05-17-2021, 06:38 PM
  Both hinges completely failed phuzy 20 11,198 01-02-2024, 02:03 AM
Last Post: Uturn
  eMMC failed Dendrocalamus64 9 7,122 11-12-2021, 11:08 AM
Last Post: Dendrocalamus64
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,467 04-02-2021, 06:45 PM
Last Post: tkudog
  microSD card stuck charlesnorris 7 8,085 11-19-2020, 05:11 AM
  NVME SPI Update not booting SD Card WZ9V 5 6,504 10-18-2020, 08:36 PM
  Upgrade eMMC card - boot problems alpopa 0 2,308 09-16-2020, 12:31 PM
Last Post: alpopa
  PBP not booting screen blank after SD card boot Jakobp 10 13,868 08-18-2020, 08:56 PM
Last Post: trinapicot
  Privacy switches - cutting power to wifi card as400 1 2,821 08-10-2020, 09:48 AM
Last Post: belfastraven
  SD card slot stefan.schumacher 1 3,086 03-28-2020, 04:34 PM
Last Post: zaius
  USB-C HUB: sd card slots and USB ports not usable vfr400racer 2 4,174 12-15-2019, 03:50 AM
Last Post: vfr400racer
