Pine Book Pro Charging Problems
(03-06-2021, 11:56 AM)KC9UDX Wrote: Were you originally charging with USB-C or the "barrel jack"?
Originally barrel jack (which needed tape fixing).
But now I saw that I may have misinterpreted the data ... seeing other reports now, it likely is the kernel issue ... how/when to fix that?
Joh
Pine Book Pro Charging Problems - by balin - 03-06-2021, 07:55 AM
RE: Pine Book Pro Charging Problems - by KC9UDX - 03-06-2021, 11:56 AM
RE: Pine Book Pro Charging Problems - by balin - 03-06-2021, 01:29 PM
RE: Pine Book Pro Charging Problems - by KC9UDX - 03-06-2021, 10:30 PM
RE: Pine Book Pro Charging Problems - by balin - 03-07-2021, 02:55 AM
RE: Pine Book Pro Charging Problems - by balin - 03-07-2021, 10:23 AM
RE: Pine Book Pro Charging Problems - by KC9UDX - 03-07-2021, 10:57 PM
Photo P{inebook Pro not charging Ome Ko 6 2,113 11-09-2023, 03:29 PM
Last Post: tomekdev
  After update, multiple problems, pinebook pro. jd50i 1 1,096 09-16-2023, 09:41 AM
Last Post: jd50i
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,636 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,396 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  Hardware problems with PineBook Pro James Good 7 8,362 07-09-2021, 12:24 PM
Last Post: moonwalkers
  HArdware issues while charging user18130814200115 2 2,887 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,674 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,976 01-25-2021, 08:48 PM
Last Post: bchenlee609
  Sudden Pinebook Pro boot problems ndp 3 4,217 01-21-2021, 09:51 AM
Last Post: ndp
  USB-C Charging on the PBP? Paulie420 33 36,488 12-12-2020, 02:20 PM
Last Post: wrzomar
