Booting Linux/Debian from the eMMC
Fixed it! I'm thinking the issue was with the SPI flash. Since this RockPro64 was one of the first V2.0 boards I guess it has an old image on it.
First, after booting with the SD card to Linux (SW4 jumper was removed), I then dd'd the same image used on the SD card to the emmc device, in my case /dev/mmcblk2. I then downloaded
https://github.com/ayufan-rock64/linux-u...95f6152134 (u-boot-flash-spi-rockpro64.img.xz)
to a PC with an SD card reader/writer. When the dd completed, I did a shutdown -h. Removed the SD card, burned the u-boot image (the unzx'd image) to the SD. Put the SD in the RockPro64 and booted it up. This took several minutes. I was then greeted by the intitial boot up of my image (asked to to set a root password and add a new user). I just did an apt update on the RockPro64. I've also removed the SD card as it doesn't show in the df or mount commands. I then rebooted, watched the console (still getting the "bad CRC, using default environment") and I've booted to the rockpro64 login prompt.
I'll now get busy restoring the services I had running previously and do an apt upgrade also, uhm first.  Rolleyes
Booting Linux/Debian from the eMMC - by linuxha - 03-02-2021, 08:49 AM
RE: Booting Linux/Debian from the eMMC - by linuxha - 03-02-2021, 07:01 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 517 03-25-2024, 12:12 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 854 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,556 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,336 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 569 04-23-2023, 11:02 PM
Last Post: Thisone
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,029 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,366 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  RockPro64 linux console video mode callegar 0 892 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,279 04-30-2022, 03:57 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,447 02-19-2022, 06:44 AM
Last Post: sigmaris
