Mobiian Community edition issue after spalsh screen
(03-07-2021, 04:11 AM)bingo600 Wrote:
(03-01-2021, 10:45 AM)C0ffeeFreak Wrote: You shouldn't use the latest image. They are broken. Use the installer image if you want an encrypted drive and update it as per the blog instructions I linked in the first post. This is the factory image that comes on the Mobian CE Edition. The encrypted installer image. Bottom one.gz
https://images.mobian-project.org/pinephone/installer/
If encryption isn't important to you and you want less updates to download. the latest image not broken is this one. Still run the updates in the blog. Choose the Feb-10th .gz
https://images.mobian-project.org/pinephone/nightly/
If you want to tweak or learn more about Mobian this is an excellent source.
https://wiki.mobian-project.org/doku.php?id=start
I haven't used my PP (CE UBPort) for a while , last SD rewrite was 2020-11
I's like to see what status we're at now , and would install a nightly (2021-feb-10) as per above advice ..
Is there any newer stable nightly ??  - Encryption is not a req. for now.
TIA
/Bingo
The latest nightly is supposed to work. https://images.mobian-project.org/pinephone/nightly/
However, if you run this in the terminal It will bring you up to date with the latest nightly.:
sudo apt update && sudo apt dist-upgrade
sudo apt autoremove
(03-07-2021, 05:17 AM)ncc Wrote: running mobian nightly 20210301 on PP KDE 3GB, and works great so far! i tried FDE from alpha3 before but i have the feeling the encryption makes everything a little slower.. can anyone confirm?
Once you boot a phone and decrypt it using your decryption code your drive is decrypted. There is no speed difference. It doesn't encrypt the drive again until you shut down the phone or reboot so other then boot decryption time there is no speed difference in actually using the phone.
RE: Mobiian Community edition issue after spalsh screen - by C0ffeeFreak - 03-07-2021, 02:45 PM
  Screen auto-rotation sensitivity mdk 0 305 12-26-2023, 06:08 AM
Last Post: mdk
  New keyboard issue sandspur 29 12,902 10-05-2023, 02:27 AM
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,250 07-17-2023, 01:49 AM
Last Post: junelung
  Screen stay black unless power key pressed short freelectro 0 688 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,469 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,262 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,035 01-13-2023, 03:33 AM
Last Post: mdk
  Possible solutions to the battery draining issue? 3x5co 5 2,532 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 5,526 09-21-2022, 02:39 PM
Last Post: Katsujinken
  how to split screen? andrew907 2 1,597 08-08-2022, 09:38 AM
Last Post: andrew907
