Plasma Mobile airplane / aeroplane mode / mobile off
I hoped the ofonoctl command as per https://git.sr.ht/~martijnbraam/ofonoctl
sudo ofonoctl offline
would work but it doesn't.
Same with modem power off command
sudo ofonoctl poweroff
it doesn't do anything.
and service start / stop / restart doesn't work either for ofonod, I don't know how to start / stop it properly.
Worked it out:
Stop ofono:
sudo systemctl stop ofono
Start ofono:
sudo systemctl start ofono
After ofono start (if turned off before), modem power is off and offline, so you need to do:
ofonoctl poweron && ofonoctl online
You can check the status with:
ofonoctl list
and for WWAN:
ofonoctl wan
Note that
ip a
and
ip route
do not show any WWAN routes so perhaps mobile data is actually off?
RE: Plasma Mobile airplane / aeroplane mode / mobile off - by dcinoz - 02-22-2021, 06:51 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,627 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,816 03-02-2023, 07:25 PM
  Flight mode turns off wifi but not the modem (cellular) jojuma 2 1,379 02-28-2023, 01:58 PM
Last Post: calinb
  gnome-mobile dev Uturn 1 1,124 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 4,928 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,590 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 7,257 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,302 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,505 07-28-2022, 12:40 PM
Last Post: johaennessen
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,004 07-04-2022, 11:42 AM
Last Post: tuxmain
