PBP won't power. Charge light solid orange/red but turns off.
No. The odd thing is that I've seen reports that the exact ones I use don't work. I've not personally found any that don't work. I've got some Sandisk ones (don't know offhand what model) and some from the Pine64 store.
Do you see the same thing on the console with different operating systems? I'd be inclined to try NetBSD just because it gives you the boot menu and the boot prompt, which if nothing else, you could stall a while before booting to see if something is indeed overheating or something.
RE: PBP won't power. Charge light solid orange/red but turns off. - by KC9UDX - 02-14-2021, 11:10 PM
  New RockPro64 Power Up Problem enorbet2 7 5,139 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,868 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,951 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,436 03-14-2021, 09:05 AM
Last Post: xalius
  Cannot charge and NO Wifi? jiapei100 3 5,499 06-27-2020, 02:11 PM
Last Post: jiapei100
  howto power hdd via usb3 on rockpro64 hanscees 2 5,123 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,798 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,141 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,559 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,148 10-23-2016, 12:16 PM
Last Post: dkryder
