Green power LED not working
The green power LED on my Pinephone has stopped working though the phone works normally otherwise. It's been a while since I had this thing apart - are the LEDs integrated into the mainboard? I'm wondering if it could be a loose connection, but if soldered to the mainboard I assume the LED just went bad. It's only a minor nuisance since everything else seems to work OK, aside from the vibrator which I'd posted about previously.
No power light, no vibrator... maybe the battery will last a wee bit longer. Big Grin
Green power LED not working - by Zebulon Walton - 02-07-2021, 07:26 AM
RE: Green power LED not working - by dukla2000 - 02-07-2021, 10:06 AM
RE: Green power LED not working - by scholbert - 02-08-2021, 04:32 AM
RE: Green power LED not working - by kqlnut - 02-08-2021, 08:28 AM
RE: Green power LED not working - by fernando_c_m - 02-12-2021, 01:00 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 540 02-17-2024, 04:15 PM
Last Post: vortex
  Pinephone - broken power button rorus 10 9,253 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,528 03-20-2023, 12:54 AM
Last Post: bcoyle
  modem not working michelinux 0 930 02-16-2023, 04:56 AM
Last Post: michelinux
  Power supply vs battery albafrati 11 4,659 06-22-2022, 06:04 PM
Last Post: albafrati
  Hardware switch for mic is not working properly submariner 10 7,674 01-25-2022, 07:01 AM
Last Post: wibble
  New vibration motor not working Zebulon Walton 5 5,571 11-13-2021, 03:00 AM
Last Post: kqlnut
  Power consumption during the call some_pinephone_user 0 1,147 10-29-2021, 06:03 AM
Last Post: some_pinephone_user
  on off power button stopped working dcinoz 3 2,576 09-01-2021, 03:26 AM
Last Post: dcinoz
  Won't boot until connected to power after sudden power loss brb78 1 1,734 08-30-2021, 12:41 AM
Last Post: bcnaz
