on off power button stopped working
Another thread mentions the $1 "PINEPHONE SIDE KEYS FLEX PCB" https://forum.pine64.org/showthread.php?...3#pid91693
I just took apart the Pinephone to replace the earpiece speaker and the on/off button no longer works - or at least not very often, I have to plug in USB-C cable to turn it on. And I can't reliably turn the screen on / off with the power on/off button.
I have removed the back cover and the inner plastic cover that goes round the back - the volume / on / off flexi cable is fully inserted into the motherboard 'slot'.  Vol up / down works fine, still. Looking at the side where the black and white 'cover' is on the vol up/down and on/off keys with a torch, the top of the on/off key area seems to have lots of small creases / thin vertical lines across the top half - I don't know if that would be the issue or the flexi itself?
Standard shipping to Adelaide, Australia is US$12, so very expensive US$13 total. Is there anywhere else I can buy it with more reasonable shipping?
Any suggestions as to what I could try to 'fix' this? I'm starting to realise that a lot of parts seem very fragile and can apparently be easily damaged when taking apart / putting back together. I have been very careful but you have to bend the flexi to get it back into the motherboard 'slot'.
Thanks for any advice. Anyone in Australia ordering something please let me know - it would be great to be able to reduce shipping costs. Not quite sure if I can live with it as it is. I might just switch back to my Android phone with Lineageos and without google apps!
(07-24-2021, 05:07 AM)dcinoz Wrote: Hi,
Please PM your shipping address to me, I will mail one PinePhone side keys witch boar to you using normal envelop.
Thanks for the offer, very much appreciated.
If anyone has instructions on how to replace the flex, thanks for letting me know.
@tllim thanks a lot for the flex, I have received it.
I removed the old one carefully (it is stuck on a metal strip) using a screwdriver and razor blade. The new one can be stuck in place (remove plastic from the rear and it's ready to go).
I connected the new flexi to the motherboard and the on / off button works, as do the volume up/down buttons!
I'm not sure how to avoid the issue again if I connect / disconnect it in the future.
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 528 02-17-2024, 04:15 PM
Last Post: vortex
  Pinephone - broken power button rorus 10 9,221 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,526 03-20-2023, 12:54 AM
Last Post: bcoyle
  modem not working michelinux 0 928 02-16-2023, 04:56 AM
Last Post: michelinux
  Power supply vs battery albafrati 11 4,652 06-22-2022, 06:04 PM
Last Post: albafrati
  Hardware switch for mic is not working properly submariner 10 7,671 01-25-2022, 07:01 AM
Last Post: wibble
  New vibration motor not working Zebulon Walton 5 5,569 11-13-2021, 03:00 AM
Last Post: kqlnut
  Power consumption during the call some_pinephone_user 0 1,147 10-29-2021, 06:03 AM
Last Post: some_pinephone_user
  Won't boot until connected to power after sudden power loss brb78 1 1,734 08-30-2021, 12:41 AM
Last Post: bcnaz
  Regarding USB Power and Modem Initialization vidual 2 2,734 08-26-2021, 11:48 PM
Last Post: vidual
