Unable to read sd card
(02-09-2021, 03:20 PM)The3DmaN Wrote:
(02-09-2021, 03:11 PM)bmeinka Wrote:
(02-09-2021, 01:09 PM)The3DmaN Wrote:
(02-09-2021, 12:38 PM)bmeinka Wrote:
(02-08-2021, 08:56 PM)The3DmaN Wrote: Just a question because I have seen users do this before (not saying this is the case here but have to ask anyway). Is the sd card in the correct slot? It is a double slot. Top is for the sd and bottom for the sim.
Other questions assuming the above question does not apply:
Are you trying to boot from the sd? (This is what the sd slot is intended for. It is the first boot device)
Are you trying to mount the sd while booted from the EMMC?
It is in the correct slot. I am trying to boot from it, although trying to mount it while booted doesn't work either.
I have already verified that the sd card is not counterfeit and that the flashed image isn't corrupted.
Hmm. Which Distro are you trying to boot, and what was your method of imaging the card (dd, Gnome-Disks, Etcher)?
I have tried:
  • Arch Linux ARM
  • Jumpdrive
  • Ubuntu Touch
  • PostmarketOS edge and stable
I started off using dd, but switched to etcher after a few failed attempts to boot in hopes I was flashing the sd cards wrong. Got the same results either way.
Sounds like maybe it is not software and could be hardware related as you suggested earlier. Etcher should work fine for that, and if its in the correct slot and not a bad sd card, I am not sure what else it could be. Maybe put a support ticket in and see if there are any other suggestions from them.
Thank you for your time. I have contacted support.
Unable to read sd card - by bmeinka - 02-05-2021, 06:24 PM
RE: Unable to read sd card - by The3DmaN - 02-08-2021, 08:56 PM
RE: Unable to read sd card - by bmeinka - 02-09-2021, 12:38 PM
RE: Unable to read sd card - by The3DmaN - 02-09-2021, 01:09 PM
RE: Unable to read sd card - by bmeinka - 02-09-2021, 03:11 PM
RE: Unable to read sd card - by The3DmaN - 02-09-2021, 03:20 PM
RE: Unable to read sd card - by bmeinka - 02-09-2021, 07:03 PM
RE: Unable to read sd card - by Alfiory - 02-10-2021, 12:55 AM
RE: Unable to read sd card - by bmeinka - 02-10-2021, 10:53 AM
RE: Unable to read sd card - by Alfiory - 02-10-2021, 11:25 AM
  install iso from sd card to emmc aular 2 444 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 1,061 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 2,562 06-11-2023, 12:30 AM
Last Post: AndyM
  Device Unable To Read MicroSD Card _radv_ 19 6,523 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 1,552 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 2,138 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,493 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 5,229 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  Won't boot - Failed to read Who-Am-I register nocargo 6 5,557 04-30-2022, 06:11 PM
Last Post: TRS-80
  SIM card slot not working dekrets 2 2,264 02-12-2022, 11:09 AM
Last Post: dekrets
