(potential) work-around for Playstore authentication issue
#19
(07-06-2016, 12:20 PM)NexusDude Wrote:
(07-05-2016, 12:54 PM)Danja Wrote: Since I did the account reset and have the onboard clock battery I've not had this issue back btw.
That's great.
After I installed a 3V battery to power the RTC, and doing Settings / Accounts / New Account / Google, the authentication issue was gone... for about 8 hours. I was just about to report my success, when it returned.
Angry
The Clock Sync app shows that the clock gets off sync with NTP, despite the RTC powered by 3V battery.
My testing suggested that this isn't a clock issue, but I'm not sure now. Maybe it's a clock issue, plus something else? I'll use Clock Sync and the RTC battery together, to try to keep my Pine's clock synchronized with pool.ntp.org. We'll see...
I plan to make a new Android code release on next two days with GSM 5.1r4 package, and this include latest App Store code. hopefully this can resolved the Play Store mystery.
RE: (potential) work-around for Playstore authentication issue - by tllim - 07-07-2016, 11:39 AM
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 4,481 11-16-2017, 02:14 PM
Last Post: Skivholme
  Playstore Selections Limited in 7.1 TV CharlieB 2 3,546 10-19-2017, 12:24 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 4,241 08-29-2017, 12:05 AM
  VPN issue on Pine64 pinea64.edison 4 6,534 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 11,289 06-02-2017, 01:32 PM
Last Post: Bob123456789
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 7,041 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,158 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 6,001 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,655 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 2,630 09-11-2016, 06:29 AM
Last Post: ameth
