Disabling screen timeout for plasma mobile
(02-19-2021, 12:59 AM)pagesix1536 Wrote: It's not quite what I'm looking for.  I'd like to just adjust the timeout value.  It's nowhere to be found.  One would think there'd be a power-settings, lock screen settings, or display settings section in the "Settings" app... but I guess not.  Still searching....
rp3's tip has been very handy.  It seems that there are still some power management problems when the phone is on standby.  I have just left the widget on the screen and made sure presentation mode was selected.  It leaves the modem on even if you turn off the screen.
If you are having trouble finding it, just open the phone to the main screen.  Then press and hold the main screen.  An "add widgets" button will appear at the bottom.  Press that button, then select the monitor icon.  The widget will attach to the main screen and will give you the option to select Presentation Mode.
RE: Disabling screen timeout for plasma mobile - by neil2ball - 02-19-2021, 04:22 PM
  screen brightness Uturn 1 753 10-09-2023, 04:38 AM
Last Post: Eugo
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,711 10-02-2023, 05:07 AM
Last Post: Uturn
  screen brightness locked Uturn 0 695 07-07-2023, 09:38 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,929 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 883 02-24-2023, 12:56 PM
Last Post: jakfish
  gnome-mobile dev Uturn 1 1,143 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 5,037 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,612 11-22-2022, 05:00 PM
Last Post: Chief
  Screen timeout makes alarm and timer unusable... Eugo 9 4,140 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,980 09-29-2022, 12:42 PM
Last Post: Firewave
