Disabling screen timeout for plasma mobile
(01-27-2021, 05:40 AM)rp3 Wrote: Hi everyone, I just thought I would share something I stumbled across the other day, which seems very difficult to find on the web?
How to disable the very short screen timeout for plasma on the pinephone.
-This can be an incredibly distracting issue, -maybe it needs dealing with?
I happened to long-press the desktop, and "Add Widgets" appeared
I pressed this, and tried adding the "Display Configuration" widget.
It had something called "Enable Presentation Mode", which I tried.
This seemed to work, and the screen then stayed on indefinately -Yay!
Perhaps this is helpful to someone else?
Regards.
Respects; I have not used my P64 for awhile and hit the fast time out first thing. Angry Thanks to your post, I rectified it. Of course, as I followed our instructions, it started to come back to me (DOH!) but you got me going. Thanks!
RE: Disabling screen timeout for plasma mobile - by christev1 - 09-05-2022, 03:50 PM
  screen brightness Uturn 1 718 10-09-2023, 04:38 AM
Last Post: Eugo
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,620 10-02-2023, 05:07 AM
Last Post: Uturn
  screen brightness locked Uturn 0 674 07-07-2023, 09:38 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,805 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 864 02-24-2023, 12:56 PM
Last Post: jakfish
  gnome-mobile dev Uturn 1 1,119 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 4,915 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,586 11-22-2022, 05:00 PM
Last Post: Chief
  Screen timeout makes alarm and timer unusable... Eugo 9 4,053 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,953 09-29-2022, 12:42 PM
Last Post: Firewave
