SMS notification inconsistent and Wifi issue (waking up?)
(01-20-2021, 05:06 AM)as400 Wrote: I'm sure what we could do, about wifi module, is to reload it (with systemd) everytime you wake up the phone and enter Phosh.
@as400
Here is a script to automatically reload Realtek wifi / BT driver when coming out of sleep / suspend:
Create an executable file here:
sudo nano /usr/lib/systemd/system-sleep/reload_realtek_driver.sh
sudo chmod +x /usr/lib/systemd/system-sleep/reload_realtek_driver.sh
Content of reload_realtek_driver.sh as an example:
#!/bin/sh
case $1/$2 in
  pre/*)
        sudo logger "`date`     Phone going to sleep..."
        sudo echo "`date`       Sleep" >> /home/mobian/reload_realtek_driver.log
  post/*)
        sudo logger "'date'     Reloading Realtek wifi / BT drives as waking up from sleep..."
        sudo echo "`date`       Waking up and reloading Realtek wifi / BT driver" >> /home/mobian/reload_realtek_driver.log
        # reload realtek driver
        sudo rmmod 8723cs
        sudo modprobe 8723cs
esac
Script does nothing on suspend (pre). Not sure where logger is output, if at all.
Systemd journal log can be seen using the following command:
sudo journalctl -b -u systemd-suspend
You can comment out the echos to reload_realtek_driver.log in home directory.
To see its logs:
cat ~/reload_realtek_driver.log
I don't know if there are any undesirable side effects so please let us know.
I don't know if it prevents the intermittent wifi issues but please let us know.
RE: SMS notification inconsistent and Wifi issue (waking up?) - by dcinoz - 01-20-2021, 07:21 PM
  New keyboard issue sandspur 29 13,273 10-05-2023, 02:27 AM
  System won't suspend due to suspention notification user641 6 1,662 09-24-2023, 05:47 AM
Last Post: user641
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 2,023 07-18-2023, 08:54 AM
Last Post: junelung
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,278 07-17-2023, 01:49 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,330 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 1,588 01-12-2023, 03:06 PM
Last Post: user641
  Possible solutions to the battery draining issue? 3x5co 5 2,598 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 5,664 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,977 06-02-2022, 07:16 AM
Last Post: arkadione
  Problem with wifi kubussz 0 912 04-02-2022, 12:57 PM
Last Post: kubussz
