SMS notification inconsistent and Wifi issue (waking up?)
Mobian up-to-date.
Phone asleep.
1. Text verification SMS sent by website. Screen wakes up. Then turns off. No blinking blue notification light. Unlock phone, open SMS app and SMS is there.
2. Website error so go through the process again, literally one or two minutes later. Presumably because phone was woken up previously, I get the blinking blue notification light (screen does not light up). Unlock screen, SMS is there.
3. Have to allow cookies as still get an error, so third time website sends SMS (literally 1 or 2 minutes later). This time, nothing. No notification light. Unlock phone, SMS is there.
4. I've turned on wifi via the command line (sudo nmcli radio wifi on), it initially connected, seems to have disconnected. My network is showing up in Visible Networks with a tick next to it but I don't seem to actually be connected. Can't ping, can't SSH into phone.
Wifi off then back on, still nothing. Settings GUI bug as wifi on / off is blue but Visible Networks is blank.
Whilst having the wifi issue, popup on the screen saying SMS text message received!
Turn wifi off via GUI - says phone is in airplane mode! Turn wifi back on via GUI, bluetooth is turned on so I turn it off (bluetooth scanning is fine). Wifi Visible Networks is blank, though it does show swirling circle so suggests it thinks it is scanning wifi networks.
dmesg shows sunxi-mmc 1c1000.mmc data error, sending stop command
dmesg shows sun81-ce 1c1500.crypto Fallback for ecb-aes-sun8i-ce is ecb-aes-ce
Wifi doesn't connect. Forced to reboot.
Phone restarted, can SSH into phone before unlocking phone so wifi now works again properly.
$ uname -a
Linux mobian 5.9-sunxi64 #1 SMP PREEMPT Sun Dec 13 13:56:38 UTC 2020 aarch64 GNU/Linux
I've turned wifi off and back on via command line and was connected immediately.
I'm not sure whether this should be reported anywhere as it seems to be related to the ongoing modem waking up the phone issues?
Happy to take pointers on what to do to try and debug if the problems arise again.
Thanks to the developers for all their work btw!  Smile
SMS notification inconsistent and Wifi issue (waking up?) - by dcinoz - 12-21-2020, 07:55 PM
  New keyboard issue sandspur 29 12,703 10-05-2023, 02:27 AM
  System won't suspend due to suspention notification user641 6 1,484 09-24-2023, 05:47 AM
Last Post: user641
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,928 07-18-2023, 08:54 AM
Last Post: junelung
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,224 07-17-2023, 01:49 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,269 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 1,514 01-12-2023, 03:06 PM
Last Post: user641
  Possible solutions to the battery draining issue? 3x5co 5 2,469 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 5,411 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,889 06-02-2022, 07:16 AM
Last Post: arkadione
  Problem with wifi kubussz 0 890 04-02-2022, 12:57 PM
Last Post: kubussz
