Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
(04-25-2021, 04:06 AM)moodroid Wrote: Hi @kop316 ,
Hope it's OK to post this here. I don't ever use MMS, but I do have a problem with some SMS's (which maybe invalid in some way?). Auto generated SMS's, e.g. bank logins, usually never arrive (although they occasionally do). They come through fine if I put my SIM in an Android phone.
sudo mmcli -m 0 --messaging-list-sms says No sms messages were found
They are not displayed in chatty, and are not in chatty-history.db.
sudo -u mobian dbus-monitor --system "type='signal',interface='org.freedesktop.ModemManager1.Modem.Messaging'" nothing appears like it would for a 'proper' SMS
Is there anything in your set of changes that I could try out to see if it helps? Anything else I can try?
Many thanks
You are welcome to post! Unfortunately nothing I have can help on that. Though that is odd you don't see them. I would suggest asking the modem manager devs, especially if you have a log.
RE: Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! - by kop316 - 04-25-2021, 06:59 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,644 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 1,019 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,634 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,126 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,238 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,730 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,282 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 131,632 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,143 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,744 06-13-2022, 02:01 PM
Last Post: israel
