Pinephone: OpenGL support?
Does either the Pinephone or Pinephone Pro offer conventional OpenGL support, or are they limited to OpenGL ES?
And is there any hardware acceleration?
Thanks.
The OpenGL vs OpenGL ES comparison is a bit tricky. In general, ES is a subset of a given version of "full" OpenGL. However, if a program expecting full GL doesn't use any of the missing features (how many features are missing also depends), then there's no functional difference.
The GPU in the original PinePhone can do ES 2.0, which is pretty close to full OpenGL 2.1. The PinePhone Pro can do ES 3.1, which can also run full 3.1 applications most of the time. There's also work towards 3.2 support as well.
"Hardware acceleration" is a broad term, so you would have to specify. If you mean 3D acceleration or video encode/decode, the answer is yes.
Well, it depends on whether you want hardware acceleration or not.
If you want hardware acceleration, then refer to what fire219 said.
If you don't need hardware acceleration, you can get almost everything Mesa supports for OpenGL by using the zink driver (set the environmental variable MESA_LOADER_DRIVER_OVERRIDE=zink) which does OpenGL over vulkan. Now, the original PinePhone does not have accelerated vulkan at all (no idea on the PinePhone Pro), so it does vulkan using the lavapipe driver, which is a pure software implementation of vulkan and therefore has no acceleration. This works quite well, just is slow is all. Very useful for some programs.
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,215 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 3,989 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 480 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,439 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,554 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,019 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 102,476 11-17-2023, 08:37 AM
Last Post: Uturn
  Using Signal on PinePhone in mid-2023? dante404 45 13,367 11-17-2023, 04:23 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 998 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,319 10-24-2023, 08:57 AM
