Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
I have made a fair amount of progress on the chatty integration! It is on feature parity with purple-mm-sms, but work is needed to polish it (and to get mm-account ready for general usage).
It is here:
https://source.puri.sm/kop316/chatty/-/t...mm-account
I warn you, BACK UP your $(HOME)/.purple if you try this! the new chatty converts the database into a newer format, which will not work on older ones.
RE: Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! - by kop316 - 02-08-2021, 05:55 PM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,611 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 1,005 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,622 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,097 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,221 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,720 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,273 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 131,224 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,133 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,725 06-13-2022, 02:01 PM
Last Post: israel
